Old 10-13-2019, 10:45 PM   #1
Leroy-B1
1960 apache lowering options
Was wondering if there was a good way to lower the 60-62 style with the torsion bar front suspension or am I better off to swap in a 73-87 front cross memeber? I have both but truck is a factory v8 and wanted to keep original motor in it
Leroy-B1 is offline   Reply With Quote
Old 10-13-2019, 11:10 PM   #2
slepysal
slepysal's Avatar
Re: 1960 apache lowering options
So how low do you want to go?
If you want to lay rail then you will have to swap out the torsion bar suspension. You can air bag a 60-62 but the torsion bars will need to be removed
The torsion bolt/key cross member will limit your drop with stock set up
I am running drop spindles and cranked torsion bars up front with some drop springs out back. This is about how low I can go due to my headers .
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 10-14-2019, 09:47 AM   #3
Leroy-B1
That height would work I'm thinking...did you add disc brakes? tell me more about your setup if you don't mind
Old 10-14-2019, 04:29 PM   #4
forestb
forestb's Avatar
I used to have a 4.5 inch drop on mine. 2.5 inch drop spindles and around 2 inches using the torsion bars. That is the way I would go.
forestb is offline   Reply With Quote
Old 10-14-2019, 06:11 PM   #5
LVPhotos
LVPhotos's Avatar
2.5" drop spindles and bars if not bagging. This is all bar before bags for me. Rear was bagged. The full truck photo is 235/60/15, the other is 215/70/15 at 27" tall a lil closer to height of the 245/45/18s that it rolls on now. This is as low with 3" clearance on inner fenders... note pork chops hanging
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 10-14-2019, 07:41 PM   #6
demian5
demian5's Avatar
Put a 73 cross member under it and get disks too.
Sleepysal has it dialed, but I had nothing but issues with a 60 I did.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 10-14-2019, 11:52 PM   #7
slepysal
slepysal's Avatar
No prob!!
I went with drop spindles and disc up front and a 1967 (3.73) 5 lug rearend out back. If your truck is a stick you will have to address the clutch master cylinder, but Capt. Fab has a nice set up for sale. I pieced the parts together over time ,Mccaughy spindles CPP rear springs , and shocks.POL supplied the prop valve and lines I got the master cylinder and front brakes (Disc,pads calipers,hose bearings etc) from a local parts house.
I had this post but the pics went away
http://67-72chevytrucks.com/vboard/s...highlight=1960
Old 10-14-2019, 11:55 PM   #8
slepysal
slepysal's Avatar
Thanks .... man it bugged me that you had so much trouble with yours. I kept hoping it would work out.
Old 10-15-2019, 12:48 PM   #9
doobiebro
doobiebro's Avatar
I went 2 1/2" dropped spindles and turned the torsion bars - I'm guessing around 7" total up front and 4" dropped springs in the rear. I like the very small rake I have on the stance..
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 10-15-2019, 12:52 PM   #10
forestb
forestb's Avatar
Originally Posted by doobiebro View Post
Attachment 1949814
what size front tires are you running? Vary cool truck by the way.
Old 10-15-2019, 04:03 PM   #11
doobiebro
doobiebro's Avatar
Thanx forestb! tires are 205 75 15 with a 15X7 Smoothie wheel.
