Old 10-14-2019, 10:58 PM   #1
TxCajun
TxCajun's Avatar
Source recommendations for "Front Hood Repair Panel - Lower" ?
After stripping the hood for my '66, I've found rust perforation across almost the entire front lower lip. The rest of the hood is in pretty good shape, so I'm considering repairing this with a new "Front Hood Repair Panel - Lower". I'm seeing these on line from a number of different sources, ranging from $170 to $250.
If you have successfully used one of these repair panels and can recommend a specific source or manufacturer based on quality and fit, I would certainly appreciate the information.
Thanks!
Wampus Cat Build: http://67-72chevytrucks.com/vboard/s...d.php?t=759550
TxCajun is offline   Reply With Quote
Old 10-14-2019, 11:41 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Source recommendations for "Front Hood Repair Panel - Lower" ?
You'll get the post from some saying the patch panels all come from the same place, so the brand doesn't matter, but there's threads in these forums talking about obvious differences between brands. Heavier vs thinner metal along with quality of the stampings.
Here's one thread where some discuss Top Banana and TriPlus.
http://67-72chevytrucks.com/vboard/s...hlight=Triplus
66 C20 Service Truck:
Old 10-15-2019, 06:56 AM   #3
PGSigns
PGSigns's Avatar
The one issue you run into with the front repair panel is the lack of availability of the support panel that is behind it. I have talked to the guys at keystone about making that piece available since the make it for the complete hoods. I have a hood that needs the front done but the inner piece is as bad as the front.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-15-2019, 07:53 AM   #4
jhrusk
I repced mine on my hood. I got it from a place called fixmyrust.com. It fit perfect. You can see process in my build thread.
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 10-17-2019, 05:35 PM   #5
TxCajun
TxCajun's Avatar
Jimmy
PGSIGNS: While investigating sources for the front lower patch panel that I need, I noticed that Bobs Chevy Trucks is advertising a "1962-1966 Chevy/GMC Truck Inner Front Of Hood Patch Panel". Could that be the part you are looking for?
https://www.bobschevytrucks.com/1962...l-896-100.html
