Old 10-15-2019, 04:22 AM   #1
prodjay10
Rear shocks
What would you recommend for shocks on a shortbed with coils in the rear and utility fenders?
I replaced shocks a couple years ago because of the bounce, but it didn't go away.
prodjay10 is offline   Reply With Quote
Old 10-16-2019, 11:46 AM   #2
SCOTI
SCOTI's Avatar
Re: Rear shocks
What brand & quality were the replacements?
What are the trucks specs?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-29-2019, 12:58 AM   #3
71cheyennesuperlongb
71cheyennesuperlongb's Avatar
Re: Rear shocks
It could be the shock angle on the rear shocks. Stock they laid down too flat to work correctely. No Limit.net makes a relocation kit to fix that problem.
'71 Cheyenne Super LWB - Second Owner in 39 Years!
'70 CST/10 SWB - Soon to be Daughter's truck when finished
71cheyennesuperlongb is offline   Reply With Quote
Old 11-29-2019, 12:50 PM   #4
prodjay10
Re: Rear shocks
Monroe oespectrum
1971 Chevy c10. Short box with toolbox bed. Rear suspension is coil type. Stock height
I ended up ordering some heavy duty shocks. Hopefully they help. If not I may go with the relocation kit.
Old 12-03-2019, 09:41 AM   #5
theastronaut
theastronaut's Avatar
Re: Rear shocks
No need to order a relocation kit, just swap the lower shock mounts side to side, use front-fitment shocks, and the upper shock stud that comes with new front shocks. Drill the frame rail to mount the upper stud.
Here's a link to the post that explains it better:
http://67-72chevytrucks.com/vboard/s...postid=4730005
I did this on my '66 with coil springs and it rode and drove great! The shocks can control the body motion much better with them outboard of the frame and standing straight up.
theastronaut is offline   Reply With Quote
Old 12-03-2019, 03:25 PM   #6
prodjay10
Re: Rear shocks
Nice! Thanks.
Old 12-04-2019, 08:16 PM   #7
KMC3420
KMC3420's Avatar
Re: Rear shocks
I assume this would work just the same with the 67-72 trucks?
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 12-04-2019, 09:00 PM   #8
theastronaut
Re: Rear shocks
Yes, I relocated the shocks on my '69 this way.
Old 12-04-2019, 09:05 PM   #9
KMC3420
KMC3420's Avatar
Re: Rear shocks
Awesome thanks!
Is the below the only mod you did to make them line up how you wanted them to?
Keagan
Old 12-04-2019, 10:07 PM   #10
theastronaut
Re: Rear shocks
The '69 brackets didn't have to be redrilled if I remember correctly.
Old 12-04-2019, 10:26 PM   #11
KMC3420
KMC3420's Avatar
Re: Rear shocks
So you used the original 67-72 lower brackets on your 69?
Keagan
Old 12-04-2019, 10:56 PM   #12
theastronaut
Re: Rear shocks
Yes, stock 67-72 brackets. Just flipped side to side, not redrilled.
Old 12-04-2019, 11:18 PM   #13
KMC3420
KMC3420's Avatar
Re: Rear shocks
I bought a pair from korinek on the board that are from a 66 to put on my 68 if they will fit. I like how the lower shock bolt is captured on both sides. Will likely need to redrill the holes though.
Keagan
Old 12-13-2019, 04:47 PM   #14
KMC3420
KMC3420's Avatar
Re: Rear shocks
I got my brackets and feel pretty good about these working out as I want them to. I might redrill the hole to make the shock be in better alignment with the upper frame mount but unsure at this point. I plan on running ridetech HQ shocks so I am hopeful that they fit inside the mounting tabs.
Few pics.
Keagan
Old 12-13-2019, 07:08 PM   #15
SCOTI
SCOTI's Avatar
Re: Rear shocks
Few pics.
If I recall correctly, those that re-use the OE style brackets do re-drill one hole for better alignment w/the upper located mount.
Not sure it was a 'must-do' thing though.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-13-2019, 08:24 PM   #16
KMC3420
KMC3420's Avatar
Re: Rear shocks
Thanks Scoti, I hope the OP doesn’t mind. I have asked no limit if I could purchase their upper mounts only but will make an upper mount if needed. I might bolt directly to the frame as well if all lines up well and possibly make a reinforcement plate. I am waiting on my hotchkis max swivel bushings to proceed, ordered them on 9/20 through summit.
Keagan
Old 12-13-2019, 09:16 PM   #17
SCOTI
SCOTI's Avatar
Re: Rear shocks
I see nothing wrong w/the stud-in-frame upper mount. It works on the front just fine w/a bunch more weight.
Nice/good choice on the swivel bushings. Sucks you're still waiting though.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-13-2019, 09:34 PM   #18
KMC3420
KMC3420's Avatar
Re: Rear shocks
Yes, the waiting is getting old. Holding up progress at this point, and I won’t be able to measure shock length until I get the bushings and trailing arms mounted. I think I will mount to the frame but will likely make a 3/16” thick 3x3 plate to basically reinforce the frame. Drill a hole in both the frame and new plate for the shock stud to pass through and attach the 3x3 plate with grade 8 bolts and call it done.
Keagan
Old 12-14-2019, 12:23 AM   #19
SCOTI
SCOTI's Avatar
Re: Rear shocks
Sure won't hurt anything having a reinforcement.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
