10-16-2019, 02:23 PM | #1 |
What is this part?
Hi all,
I picked up a 1970 C20 with a 402. The truck is in good shape, but came without a lot of the parts installed. Motor and tranny are out of it and the motor probably needs a rebuild. Anyways, I was looking they the parts and found these. I don’t recognize them, so here we are. Thank you in advance. |
10-16-2019, 02:37 PM | #2 |
Almost Satisfied
Re: What is this part?
These look like parts of an auto trans cross member.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
10-16-2019, 02:45 PM | #3 |
Thank you! You’re right, I had the bottom piece and didn’t realize these were part of the bracing as well.
10-16-2019, 09:10 PM | #4 |
Old member
Yep, the ends of the auto cross member.
You can see it in the picture.
