10-17-2019, 06:08 PM | #1 |
How to get the spring in to the front suspension?
Is a spring compressor the best way in this case? Ive got a front end that I am rebuilding and I finally have the control arms in and was about to install the coil and spindle but Im having a clearance issue. Ive seen videos where the coil is placed in and a floor jack is used, but Ive got the jack stands pretty high and I dont think Ill be able to use the floor jack method. I rented a spring compressor but the tool looks like it will be too tall once installed to even get it in and removed afterwards. I saw in the manual where it shows a different tool, I guess that the safest and only way at this point? Im really nervous about having this frame jacked up any higher to get clearance. Thoughts?
10-17-2019, 08:27 PM | #2 |
Re: How to get the spring in to the front suspension?
You don’t have enough wait to use a jack without engine you need to find the correct spring compressor or make one
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
10-17-2019, 10:10 PM | #3 |
I had the same problem with my coil spring. I bought an internal compressor but the bolt stuck up too high after I compressed it. I took the spring and put the top of it up in the pocket. Next I forced the bottom part into the lower control arm. Next I put my floor jack under the lower control arm. Kind of tuff with no help around . LOL!! Next I put the front bucket of my tractor on the frame. Jacked it up and hooked up spindle to the ball joints. I had the front clip off of my truck and motor was out. Good luck.
10-18-2019, 01:35 AM | #4 |
I was in the same boat and couldn’t find an easy way to do it. I ended up using an internal spring compressor like the picture. Problem was, every time I got the spring compressed enough the sucker would slip and the spring would pop and scare the hell out of me. I ended up putting the compressor on and marking where they need to sit with a sharpie and I put a blob of weld there to keep it from slipping. It worked and didn’t seem to affect the spring tension at all. You should be able to drop the extra threaded portion through the hole in the LCA. Get the ball joint installed and then release the tension.
10-18-2019, 02:38 AM | #5 |
I installed mine by building a brace out of 2x4's. One screwed in to the joists of the garage ceiling. (make sure it is long enough to hits the joists outside of your verticals) two verticals and another one across the frame. Then used a jack to raise the lower control arm into place until I could get the ball joint castle nuts on. From your pics...you will need to raise the truck up a bit to get the jack under the lower ca.
10-18-2019, 08:42 AM | #6 | ||||
Dropping the extra threaded portion through the bottom puzzles me. Wouldnt I need the fitting end so I can get the socket on it? I wondered if this type of compressor is the one to use? If I go this route I can check around to see if Autozone or Advance can rent this type. Quote:
Ill have to check the lumber pile on this one, good to have as an option. Another thought was to use ratcheting tie down straps and loop them around the base of the floor jack and over the top of the upper control arm and crank it up against the straps banding pressure. All options scare the heck out of me really. With the entire frame and cab on 4 jack stands this is making the pucker factor pretty high. |
10-18-2019, 10:42 AM | #7 |
If you cut a couple coils off, they go in real easy. Just saying (grin).
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
10-18-2019, 12:20 PM | #8 | |
That compressor you picked might be better for not slipping. |
10-18-2019, 01:00 PM | #9 |
Chevy guy
Hi
I put the floor jack under the lower arm and take a length of chain and loop it under the jack and over the top spring pocket. Then when you jack up the lower arm everything is contained and just bolt up the spindle. Jon
Tehachapi, Ca 57 BBW shortbed 64 C30 service bed 65 C10 long bed fleetside 70 C10 long bed fleetside 74 C30 flatbed |
10-19-2019, 01:53 PM | #10 | |||
Heres what it looked like, my neighbor helped out and we both survived. |
