10-17-2019, 06:19 PM | #1 |
French locks for exhaust manifolds
Who uses french locks on their exhaust manifolds? Any opinions on them? Supposedly they allow the outer bolts to have less torque and the manifold will be less prone to cracking. Some discussion of them here:
https://www.camaros.net/forums/18-en...all-bolts.html |
10-17-2019, 07:29 PM | #2 |
Re: French locks for exhaust manifolds
They are mandatory of you want the manifolds to be leak and trouble free. Dont use manifold gaskets with them either. Usually the manifold needs to be surfaced for a tight seal.
10-17-2019, 09:27 PM | #3 |
Old member
They where factory installed on all the Ram horns I have ever seen. X2 on not using a gasket on them too!
10-17-2019, 09:46 PM | #4 |
I have them on my truck, primarily because they were original to the truck. However, they should eliminate the possibility of the bolts loosening.
10-17-2019, 10:02 PM | #5 |
I use them but I never knew they were called French locks.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
10-17-2019, 10:08 PM | #6 |
There were still on mine, had manifolds resurfaced and threw out the stupid gaskets. Reinstalled the French Locks after.
1971 Custom/10 - 350/3 speed, Orange/White roof |
10-18-2019, 10:18 AM | #7 |
Those are a good idea, most just rip em off when installing new gaskets or working on the exhaust.
I have gaskets on mine, no locks, no issues, Mileage and opinion will vary. Oh I go thru and tighten them about every 6 months, needed or not. |
10-18-2019, 10:35 AM | #8 |
Do you torque the middle bolts to 30-35 ftlb and end-pairs to 15-20 ftlb, to reduce cracking of the exhaust manifold? That is supposedly what the french locks allow you to do.
10-18-2019, 01:00 PM | #9 |
x2, thats why I opened this thread, I have them on my jimmy and just use copper coat on the block and manifold
curious as to the torque numbers
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Tags |
exhaust manifold, french locks |
