Old 12-04-2003, 08:15 AM   #1
LKJR
Doors not closing good with top off
Anyone have doors that open and close smooth with the top off? I adjusted mine some when I had the top bolted on good and they were kinda stiff but opened/closed pretty smoothly (just needed a little force) but with the top off they just don't cooperate. Drivers isn't too bad but stiff, and the pass side, you have to lift it some.
I know the body tends to sag there but anyone have good luck with this situation?
1st Gen Blazers
Like em big and topless
LKJR is offline   Reply With Quote
Old 12-04-2003, 09:13 AM   #2
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
do you have the door aligning pads? Just a thought
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 12-04-2003, 12:32 PM   #3
2wdBlazer
The Blazer King
2wdBlazer's Avatar
No rocker boxes will cause this. Put some on or Do some home made bracing.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 12-04-2003, 02:46 PM   #4
LKJR
I've got rocker boxes.....and there not rusted out...
1st Gen Blazers
Old 12-04-2003, 03:43 PM   #5
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Shot body mounts can also cause the sag. Put the top back on and get the doors working properly and then try some new body mounts. Or you could take the doors off too like K5Krazie!
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 12-04-2003, 05:51 PM   #6
meathead95
computer illiterate
meathead95's Avatar
are your hinges rusted out? my passenger door upper hinge is rusted out around trhe hinge plate and it is a mother to close sometimes
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 12-05-2003, 12:34 AM   #7
slogo
slogo's Avatar
do you have a lot of rust in your lower kick panel might need to address that area if you do.
slogo is offline   Reply With Quote
Old 12-05-2003, 02:59 AM   #8
72beast
TONYP
72beast's Avatar
i can get my doors to work so nice with the top off, but one damn 4x trop and there all out of wack...I think with the top off you just have to mess with them
72 K/5
350/205
SOFT-TOP
DOUG THORLEY HEADERS
A/C
CUSTOM REAR BUMPER
http://www.socalbigdawgs.com/tr/7.18.03/DSC04290.JPG
72beast is offline   Reply With Quote
Old 12-05-2003, 09:00 PM   #9
JimKshortstep4x4
Talking
Another thought is to check out the body to frame alignment. There is a procedure in the assembly manual that addresses this and it is worth looking into.
Jim
Old 12-06-2003, 12:59 AM   #10
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
My driver's side is a pain,but it's because the upper hinge pocket need 's help..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-10-2003, 12:58 AM   #11
blazerslave
blazerslave's Avatar
JayDub . . .
Where are the door aligning pads located? My doors fit funny since I took the top off too? I am working with my body man to figure this out.
blazerslave is offline   Reply With Quote
Old 12-10-2003, 01:36 AM   #12
72beast
TONYP
72beast's Avatar
the pads are right under the seats and about even with the back of the seats, two on each side. I used some thick washers and cut a slot in them (like starter shims) so I didn't have to remove the bolt, I just loosened them and slid them in....
72 K/5
350/205
SOFT-TOP
A/C
CUSTOM REAR BUMPER
