Old 10-19-2019, 04:21 PM   #1
Grumpy old man
Grumpy old man's Avatar
Good deal on rear shock relocate
I found this deal on rear shock relocate kit
https://www.amazon.com/Pickup-Reloca.../dp/B07MF76LN8
Free shipping arrived in 2 days , $38.80 total all grade 8 hardware included , 1/4" thick steel .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 10-19-2019, 08:07 PM   #2
LakeAnna
LakeAnna's Avatar
Re: Good deal on rear shock relocate
They look good. Did you ever figure out the Bilstein shock numbers?? I was kinda waiting for your other post to update. LOL
Chris
72 RESTO
http://67-72chevytrucks.com/vboard/s...d.php?t=501870
LakeAnna is offline   Reply With Quote
Old 10-20-2019, 07:49 AM   #3
That's cheap. Looks good. Let's see how they fit.
Old 10-21-2019, 04:29 AM   #4
Hammond68
What are the benefits of relocating the shocks? I'm sure there is but just don't know the reason.
1972 c10 cheyenne.
383 stroker 10-1
280 magnum comp cams
700r4 tranny.
Hammond68 is offline   Reply With Quote
Old 10-21-2019, 06:38 AM   #5
Zeroman
Zeroman's Avatar
Hammond68, when you lower the suspension the angle of the shocks decreases.
Shocks tend to work better when they are more perpendicular to the frame and suspension.
These shock relocater kits allow the shocks to be more upright.
Zeroman is offline   Reply With Quote
Old 10-21-2019, 09:03 AM   #6
Hammond68
Thanks zeroman. Is the same shock used or do you then need a different lenth?
1972 c10 cheyenne.
383 stroker 10-1
700r4 tranny.
Old 10-21-2019, 10:46 AM   #7
old51sedan
old51sedan's Avatar
Great question. I know it will need a different length as I've lowered mine 4", installed a shock relocating kit and my original ones are to long. I'm not sure exactly how to measure for the new ones, that's my problem.
old51sedan is offline   Reply With Quote
Old 10-21-2019, 11:40 AM   #8
weq92f
weq92f's Avatar
Here's a guide to measuring for new shocks on a modified suspension...
https://www.shockwarehouse.com/news/...ure-shocks.cfm
...In a nut shell: measure the gap between shock mounts with your suspension fully compressed and again with the suspension fully extended. The guide describes in good detail how to get those measurements ( where to measure ). Then using those two measurements, find a shock that has the same or very close fully extended and completely compressed measurements and you've got your mark!
Hth,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 10-21-2019, 12:09 PM   #9
Grumpy old man
^ This is why I'm installing the shock relocate kit and new 5" rear springs , If I'm going to spend the money on Bilstein shocks I want to make sure I've got the right ones .
Thanks , this makes it easier .
Old 10-23-2019, 07:49 PM   #10
Grumpy old man
They fit great big difference over stock .
Old 10-24-2019, 08:26 AM   #11
Good to know. Definitely a good deal. Exactly what I need. Time for some blue and yeller now!
