Old 10-20-2019, 12:23 PM   #1
too much stuff
Roadtrip!
too much stuff's Avatar
6 cyl power steering ID?
Scored a bunch of parts this week and among them are what is supposed to be 292 power steering set up and a 250 steering setup. The 292 was pulled from a 69 and the 250 was an early 70s I was told. Can anyone confirm or deny? I don't do a lot with 6 cyl stuff...
Thanks.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 10-21-2019, 02:34 PM   #2
too much stuff
Roadtrip!
Re: 6 cyl power steering ID?
Anyone ID the pumps and brackets?
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 10-21-2019, 07:22 PM   #3
100%Chevy
The banjo shaped is for our years of trucks and cars.You'd have to match the main bracket to the right head for the exact fit.
The tear shaped is for later 70's and up.Looks a lot like the one on my 78,C-10.
Best I can do without trying to fit them to an engine.
Mike.
100%Chevy is offline   Reply With Quote
Old 10-21-2019, 07:55 PM   #4
too much stuff
Roadtrip!
Mike.
I appreciate the help. You are referring to the banjo as pic 2 and 3, correct? And the other as pic 4 and 5? I see a 72 gmc on ebay with what looks like the same setup as pic 2 and 3 , but only listed as a 6 cyl. (not sure what size)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 10-22-2019, 09:08 AM   #5
old51sedan
old51sedan's Avatar
The bracket that attaches to the motor I believe is correct for 69-72 292's. That being said everything else seems to be different. That bracket is suppose to mount directly to the pump, where yours has another bracket in between the two. The pulley is different than original and so are the adjusting rods. If you took it off from a complete engine, must be everything lined up though.
old51sedan is offline   Reply With Quote
Old 10-22-2019, 10:39 AM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Here is what I have saved for 292 PS bracket pictures. The problem is every time someone posts pictures of the brackets there is something different on them.
LockDoc
Leon
Old 10-22-2019, 11:51 AM   #7
old51sedan
old51sedan's Avatar
I understand what your saying, over the years things get changed around. Too much stuff I believe has an original bracket, but it's missing the extra piece in the first picture. That is what holds the back of the pump to the bracket. His has another piece in between that is holding it. Could you by any chance get me a number from the pulley on the last pump you have pictured there, I would appreciate it. I need a pulley for one. I need one like this one.
Old 10-22-2019, 01:58 PM   #8
LockDoc
LockDoc's Avatar
If you are talking about the pictures I posted they are all pictures I saved from the internet so I don't have access to the actual parts in those pictures. I do have a couple of PS setups from 292's but they are boxed up out in the shop somewhere.....
LockDoc
Leon
Old 10-25-2019, 08:10 PM   #9
too much stuff
Roadtrip!
Thanks for all the input guys. So it looks like I have a correct 292 set up and a 250 setup. Any idea on values? I only have what is pictured, no other pullies or anything.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
