Old 10-21-2019, 10:33 AM   #1
landarts
landarts
Help with manifold
I purchased a 68 1/2 ton about a week ago and trying to get it running. The truck has sat for a long time with bad gas left in the tank and fuel system. I am working all items to be cleaned out or replaced to get it going. The motor is a 283 and had a rebuild on it about 30K ago. I knew that the carburetor would need to be removed and rebuilt. When I tried to remove the carburetor the two front stud mounts basically were rusted through and snapped of with the slightest pressure. The two back ones were fine and no signs of rust.
I proceeded to pull of the intake manifold so I could work on getting the rusted carburetor mounts out and the threads cleaned up. As I was working on it I remembered that I had two intake manifolds from 327 motors. When I flipped them over to compare I noticed that the 327 manifold had the middle most port blocked off and the manifold from the 283 had the middle port open.
Is it ok to use the 327 manifold with ports closed or do I need to stick with the 283 manifold and get the carburetor studs fixed.
Pict 1 is the broken off studs in the 283 manifold
Pict 2 is the two side by side for comparison
Pict 3 is the truck I bought
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 10-21-2019, 10:46 AM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: Help with manifold
Nice truck...
Basically you would be doing what is in this article:
https://www.jalopyjournal.com/forum/...risers.247422/
If it is fine with you, do it. Are you using a Divorced Choke/Cable Operated/Electric Choke? A blocked port would affect the Divorced one in the cold.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 10-21-2019, 10:47 AM   #3
landarts
landarts
Originally Posted by 71meangreenc10 View Post
Nice truck...
Smitty
Right now on the truck is a cable operated choke. The carburetor is a two barrel Rochester 2 Jet.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 10-21-2019, 10:54 AM   #4
71meangreenc10
That may not matter in your situation. Use either or....
Smitty
71 C30 Wrecker
Old 10-21-2019, 11:27 AM   #5
weq92f
weq92f's Avatar
...and now that you know...you can also get a set of gaskets that block those ports effectively disabling the heat risers. It's what I did on my BBC to help keep the intake cooler and minimize heat soak issues ( was having warm starting problems ).
Hth,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 10-21-2019, 12:23 PM   #6
randy500
The blocked passage is from carbon build up. Just drill and chisel it out.
randy500 is offline   Reply With Quote
Old 10-21-2019, 08:26 PM   #7
AussieinNC
Moderator
AussieinNC's Avatar
Set the original manifold up in a drill press and drill out the original broken studs. If you need to, go one size bigger and use a helicoil to bring the thread back to standard size.
If you use the replacement manifold, clear out the carbon choked ports....
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 10-21-2019, 08:48 PM   #8
BigBird05
The 327 manifold is showing some rust in the #1 and #2 intake runners. That one will requier some clean up work. In the area of staying "original" I would fix the 283 manifold. Try soaking the studs with PB Blaster for a few days then try an EZ out.
BigBird05 is offline   Reply With Quote
Old 10-21-2019, 09:01 PM   #9
68 P.O.S.
I agree
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 10-21-2019, 10:14 PM   #10
weim55
Your 327 intake has considerably larger intake port opening so there will be a significant port size mismatch with the cylinder heads if they are correct for a 283. On a stock engine the port mismatch is unnoticeable in performance but if you use the 327 intake check very carefully that the larger ports don't create a vacuum leak at the port. If it were me I'd repair and run the 283 intake but I also have a torch setup that will almost certainly be required to get those broken studs out.
OR, hit the parts board here and post a WTB for a correct '68 307 intake setup and put her back to all original...........
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 10-22-2019, 09:28 AM   #11
landarts
landarts
I am leaning toward trying to fix the old 283 manifold. Ordered a Helicoil kit and have them soaking right now with Kroll oil. I will report the progress here shortly.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 10-23-2019, 10:10 AM   #12
landarts
landarts
Well I soaked the two carburetor mounts that were broken off with Kroll oil a couple times a day for three days. Then I center punched it a few times with a carbide center punch and started drilling with a small bit and worked my way up in size. Going slow and adding some cutting lubricate as I go. I added a little heat with a Map gas torch and kept drilling and the first one finally came out on the drill bit. Moved onto the second one and had to go all the way, then used a 5/16 18NC tap and retapped it. Then used the tap to chase down the other three mount holes. When it was good and tested the mount screws, then took it out to side of garage and sprayed it down with dollar store oven cleaner to get all the gunk off and get it ready to reinstall.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 10-25-2019, 07:54 PM   #13
AussieinNC
Moderator
AussieinNC's Avatar
I dont see a problem with your collection....
if you run out of space you could always send me a few to look after for ya...
2012 Chevy Equinox
