Old 10-21-2019, 02:13 PM   #1
Mack B
Mack B's Avatar
Seat belt opinion
Gentlemen, today on Mack worries about things that don’t matter I present the following:
Previous owner installed a 88-94ish seat in my 63 along with the shoulder belts and lap belt. The seat was reupholstered with pleats and kinda fits the vibe of said truck, but to me the plastic belts stick out like a sore thumb. I’m not a purist, but I do want my truck to look right for the period. That’s immaterial in this case though as I realized mine where for show anyway when my 8 year old pulled the belt clean out of the b pillar.
Im looking at the following designs for replacements.
I know the metal ones where used in 80s Chevrolet’s but I think they fit the 60s styling well enough.
The font on the plastic ones matches the font on my dash knobs well enough.
I’m going with black either way.
Which would you choose?
Mack B is offline   Reply With Quote
Old 10-21-2019, 02:21 PM   #2
PGSigns
PGSigns's Avatar
Re: Seat belt opinion
The metal buckle wins every time.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-21-2019, 02:38 PM   #3
Mack B
Mack B's Avatar
Jimmy
Leaning that way hard myself, but a part of me says it won’t be noticeable if it’s plastic in black and it will look like it was born there. Not being around in the 60s I have to guess on what 60s styling was
Old 10-21-2019, 03:59 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Metal buckle matches our trucks better.
Old 10-21-2019, 04:55 PM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
IMHO, they should be lift latch type buckles
2 point,
3 point,
All found at https://www.seatbeltsplus.com/
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-21-2019, 06:42 PM   #6
Mack B
Mack B's Avatar
2 point,
3 point,
I had those in a 56 sedan I owned once. It had impala seats and those definitely looked at home in there. Thanks for making this even harder
Old 10-21-2019, 07:31 PM   #7
cwcarpenter98
cwcarpenter98's Avatar
I prefer the looks of the metal buckle
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 10-22-2019, 12:56 AM   #8
Mack B
Mack B's Avatar
I appreciate all yall's input, I went over this way more than I should have. I went with the metal ones with the gm logo....after I emptied and refilled the cart 3 tImes.
Old 10-23-2019, 08:42 AM   #9
jbgroby
jbgroby's Avatar
Just as an FYI to all the OEM Seat belt installers. In the factory installation manual there were hooks offered to hang the lap belt up so it would not fall out of the truck. There were just the coat hooks offered in 55-59 from the GM Line for the cars. Cost $5.00 a set.
If you use the metal latch type design, drill a 1/2" hole on the center and you can hook them up. When I got to shows I have to explain to the judges that they are factory OEM options.
jbgroby is offline   Reply With Quote
Old 10-23-2019, 02:34 PM   #10
roll_the_dice
roll_the_dice's Avatar
I am glad someone has been struggling with the same thing! I will be going with either the latch or GM Logo.
roll_the_dice is offline   Reply With Quote
