Center Console repair
What is everyone doing to fix the stress cracks in their center consoles. My 84 has the cracks in the usual areas. I want to prep and repaint before I replace my carpet but was hoping to "fill" the cracks in first. Any ideas or what you have did would be great.
Thanks for reading!
Weev- Life's tough...... It's even tougher when your stupid - John Wayne |
Re: Center Console repair
Assuming you are talking about the 81-91 style consoles.... I drill the ends of the cracks, then use a large animal (vet type) needle/ syringe with a large dia. needle to inject 2 part epoxy (I use some 5 min set locktite clear epoxy) into the crack...once the epoxy is set enough to be tacky, I dab at it with a red rag to help blend the texture back into it. Once all done I dye the console to whichever color I am going for. I also beef up the area where the lid screws down with some JB weld, then be sure not to overtighten the lid screws when putting it back together. From what I can tell, overtightening the screws is the major contributor to the cracks to begin with.
If you are doing the old '70's style console, I haven't ever had to repair any of them, other than refinishing. I want to say that at least some of the parts on my '80 K5's console were fiberglass, so fiber glass type repairs may be in order, although the epoxy method I use on the later ones may also work. Hope I helped ya out! |
#3 | |
Thanks again for the input, super helped me out. Just wasn't thinking about plastic epoxy.
Moderator
![]() Join Date: Oct 2008
It's called stop drilling.
Cast Iron, steel, fiberglass, glass, and various plastics will continue to crack without a hole drilled at the end of the crack. The hole prevents the concentration of the spreading force in one place so it's harder for the crack to continue. You can get pieces of metal to melt into and stitch across cracks in plastics and you can get stitches to drive in across cracks in various metals. Here's a google search for cast iron stitching. https://www.google.com/search?q=stitching+cast+iron Here's a guy welding plastics DIY.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
| Bookmarks |
