12-04-2003, 01:51 PM | #1 |
Help! Front end gear ratio Id
I have what I think is a front end out of a '87 truck. It is a 10 bolt 3/4 ton (8 lug) front. Does anyone know the gear ratio by decoding the # on the axle tube? The #'s are WY G 1 252 1
Thanks, Dennis |
12-04-2003, 11:48 PM | #2 |
There should be a small metal tag on one of the cover bolts that will give you a ratio-----but the most common gear in those years was 3.73. Other than that you may have to pull the cover and look for the numbers on the ring gear.
12-05-2003, 08:20 AM | #3 |
user # 2756
Did the truck have ab auto or manual? If auto could be 3.08.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
