Old 10-23-2019, 03:49 PM   #1
wake328
centering control arm shafts
In the process of assembling my upper and lower control arm shafts. A couple of them, I struggled to even get the threads started into the arms much less have them perfectly centered.
So my question is... is there an accepted tolerance? Say .1-.2" off? Were you able to get yours perfectly centered? That seemed to be as close as I could get with most of them. I can see this affecting the caster angle.
wake328 is offline   Reply With Quote
Old 10-23-2019, 04:28 PM   #2
Wrenchbender Ret
Re: centering control arm shafts
You get them as close as you can by turning the shaft. The alignment will compensate for the rest.
George
Wrenchbender Ret is offline   Reply With Quote
Old 10-23-2019, 04:45 PM   #3
KMC3420
KMC3420's Avatar
Tagging onto this, how tight do you get the end caps once the shaft is centered? I have seen anywhere from 95 to 160 ft lbs. I have read not to over tighten them as well because it can bend the ears. Also, I have read a few times not to tighten them until the frame is on the ground and supporting the weight of the truck to avoid any binding issues. I assume the first picture (has the lower listed twice) that the first "Lower Control Arm Busing" should say "Upper Control Arm Bushing".
Uppers: 95 ft. lbs.
Lowers: 130 ft. lbs.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 10-24-2019, 09:25 AM   #4
Tommyups
I tightened mine as far as they would go
Tommyups is offline   Reply With Quote
Old 10-24-2019, 10:02 AM   #5
Grumpy old man
Grumpy old man's Avatar
Post some pictures of what your working with . I used all new moog parts and drilled the cross member for the 9/16" u bolts , install the shafts onto the frame making sure to locate the pin in the lower shaft and torque the lower shafts in place with the U bolts , then install the lower control arm onto the shaft and just catch the first thread with the cap on each end , mark the caps and alternate tightening them 1 turn on the front ,then one turn on the back until they bottom out on the control arm . once on the ground you can torque the caps, the same process can be used for the top . Much easier than trying to use a vice or on the garage floor
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 10-24-2019, 10:09 AM   #6
KMC3420
KMC3420's Avatar
Thanks Grumpy, did you torque to 95 and 130? Sorry OP, hope I am not taking away from your original question.
Keagan
Old 10-24-2019, 06:05 PM   #7
demian5
demian5's Avatar
And you can get more positive caster for better straight line handling by positioning the control arm more towards the front of the truck (maybe 1/4"). That makes a big difference.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 12-06-2019, 06:51 PM   #8
69Tom
69Tom's Avatar
Subscribed. Good info.
69Tom is offline   Reply With Quote
