Old 10-23-2019, 09:12 PM   #1
Starwood
Starwood's Avatar
Steering Box Replacement
I tried tightening the gear box (the 1/2" turn trick) and there was still too much play, so I went ahead and got a replacement.
Just checking in with you guys for any do's/don'ts before things get dirty. There is not much on YouTube for the old Chevys.
I can take it to the trusty classics shop for labor only, but hoping I can pull this off and save a few bones.
If you've swapped one of these and have a minute to share the good, bad, and ugly - I'd appreciate your comments.
64 C10 Custom
70 C10 Stepside w/67 Front End Clip
1970 Buick Ragtop
2003 Anniversary Road King Classic
Starwood is offline   Reply With Quote
Old 10-24-2019, 06:45 AM   #2
PGSigns
PGSigns's Avatar
Re: Steering Box Replacement
It is a direct bolt in. The biggest thing is to get the steering wheel straight and level and centered in the turns before you pull the box to give you a place to set the new box to. Do you need to swap the pitman arm? Check the rag joint before you pull it apart so if it needs redone you have the stuff ready when you pull the old box.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-24-2019, 07:17 AM   #3
rpmerf
rpmerf's Avatar
If you got a 4.5 turn box, a 3.5 turn box is a nice upgrade.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 10-24-2019, 04:21 PM   #4
Starwood
Starwood's Avatar
Yup - it's a 3.5
64 C10 Custom
1970 Buick Ragtop
Old 10-24-2019, 05:53 PM   #5
damnyankee36
damnyankee36's Avatar
Jimmy
Another thing to look for is to make sure the steering wheel is aligned to the shaft. Look for the two alignment marks on the shaft and steering wheel hub. That way the turn signals will cancel at equal steering wheel angles and the shaft will be centered.
damnyankee36 is offline   Reply With Quote
Old 10-24-2019, 05:53 PM   #6
cj847
cj847's Avatar
I assume the rest of your steering components are good.
The hardest part is getting the pitman arm off. You must buy (or borrow from O reileys) a Pitman arm puller. The "secret" is to put the puller on and tighten the thing really tight. You will notice that the pitman arm doesn't come off even though you are sure the puller is about to break. Take a hammer and WACK the side of the pitman arm where it is attached to the box. It should pop loose.
Suggest you put your wheel strait ahead and tie your steering wheel to something so it doesn't move while it's apart (more of a concern on new vehicles, but still good practice).
cj847 is offline   Reply With Quote
Old 10-24-2019, 06:03 PM   #7
Starwood
Starwood's Avatar
Jimmy
Thanks Man. Appreciate this - gonna check that pitman arm and rag joint for sure. Looks like I'll need an arm/rod puller for this job and a trip to Autozone is on the agenda. Thx again.
64 C10 Custom
1970 Buick Ragtop
Old 10-24-2019, 06:55 PM   #8
Starwood
Starwood's Avatar
Jimmy
Hey Jimmy - I noticed a small amount of play (maybe a 1/4") in the rag joint when I wiggle the column. Is this normal? To be clear, the play is only where the coupler meets the box. Everything else is tight upstairs.
64 C10 Custom
1970 Buick Ragtop
