Old 10-24-2019, 01:43 PM   #1
cj847
cj847's Avatar
6 cyl exhaust
What is this thing (I am guessing it is for cold starting).
Anyway, mine moves freely, but the spring is broken. Is there any issue with ignoring it? Is there a source for the spring?
cj847 is offline   Reply With Quote
Old 10-24-2019, 04:14 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 6 cyl exhaust
https://www.google.com/search?q=6+cy...HWCbCWkQsxgILg
Old 10-24-2019, 08:25 PM   #3
ACK
ACK's Avatar
Re: 6 cyl exhaust
Yup, that's the heat riser to help warm up the engine faster on cold days. Yes, you can ignore it, it's weighted in a way so that when the springs breaks, it doesn't cause bad things to happen.
Looks like your spring probably just needs the bend to hook onto the post in the picture. Warning, the post might be rusted to the point that it breaks off sooner or later. If that does happen, you can carefully drill and tap to install a new one of your own making. If you do get a new spring, the older jeeps used the same bi-metal spring but they usually cost about half as much as the Chevy version. Should you go the Jeep route, you'll have to trim it and bend a small tab to, again, hook onto that small post.
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
