![]() Join Date: Jan 2018
AC Unit on Firewall
Ok Guys, what are you using to restore the composite box that's mounted on the firewall?
Mine is in great shape, yet it's dull and doesn't look too good. Thanks in advance, Pat |
Re: AC Unit on Firewall
I've never done one but what about trunk paint?
George |
![]() Join Date: Apr 2016
If you think yours is OK, you may be surprised if you take it off and look at the inside. It depends on whether you've taken it off and cleaned it up before. I am sending mine to Original Air in Florida for restoration. Forum member F.A.A.benny also restores them. I figure once every fifty years or so, give it a complete re-do.
![]() Join Date: Feb 2009
I plan to ask F.A.A.benny to restore my entire A/C. Not sure on compressor yet, vintage air "OER" seems like a great way to go.
If I remember right, a lot of guys just scuff up the box some then hit it with a clear coat.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: May 2010
Clean it up and apply some Armor All or Son Of A Gun. Don't apply a large quantity. Let it sit 10 minutes or so and wipe it off. You'll be surprised.
#6 | |||
Pat |
![]() Join Date: Dec 2013
This heater box is for my green 67 short bed 292 truck , I cleaned this one up a few years ago and it's been stored since then waiting it's turn . it's the original piece out of the truck . I used a purple scotch pad and lacquer thinner to bring it back and remove any staining , Some light sanding it in a few areas and cleaned again with the thinner and pad . Then applied a few light coats of MATTE CLEAR . to bring back that light sheen they had when new , The purple pad works to get into all the corners and it looks great when your done , No need to ever reapply anything to it . I just wiped it off this morning to remove some dust and it looks the same as it did a few years ago .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#8 | |
Thanks for the response. Pat |
The trick is using MATTE CLEAR and spending the time to get it as clean as possible , Don't use gloss or semi gloss clear .
![]() Join Date: Dec 1999
I used gloss clear and love the result.
https://www.amazon.com/U-S-Chemical-.../dp/B0043B7UQY Wish i had a close up picture... ![]() |
Thanks for all the responses.
This is what mine came out like. Pat |
Looks great. Is that matte clear?
#13 |
That is what I used matte clear and it looks good.
