Old member
Took the carburetor off tonight and found it only had 2 bolts holding it down and both of them where loose. I thought dang 2 of them where either gone are broke off but not either one. The gasket only had 2 of the 4 bolt holes cut. It's been like this since I bought it cause I haven't touched it. Even when I had the carburetor rebuilt they said nothing about it.
The trucks been backfiring bad lately I guess I know why now. I put it back together with all 4 bolts and lock washers. I also found the passenger side exhaust flange loose again!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Does this look right?
I used to see holley 2 barrel carbs on mopar like that back in the day
Moderator
![]() Join Date: Jun 2017
2GC carbs sometimes only have two studs and nuts retaining them...
probably a cost saving exercise.... Check out that wire laying along the intake under the accelerator rod...looks like its got bare sections that could ground out... Backfiring could be lots of things... Air leaks, bad accelerator pump, bad timing, bad timing chain... Start with basics,,,,check carb for lack of accelerator pump squirt, check timing, check for vacuum leaks...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2025 Chevy Equinox ![]() ![]()
#4 | |
Old member
#5 | |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
Old member
The intake is on a 350 but it's not the original motor for the truck. I'm going to a 4 barrel Elderbrock over the winter. But for now it will do.
When does it backfire?
...and to be clear, is it backfiring through the carb?
72 C10 lwb fleetside -stock 350/350 combo |
Old member
Just when you let off the gas. I haven't drove it yet. I hope between the manifold ring being loose and this I have fixed it. I hope to drive it today and see.
I hope it's that simple as well. If so, double check the timing. It may have been adjusted to run with the carb the way it was
#11 | |
Old member
I hope it's OK though now.
#12 | |
Moderator
Has the OP determined the engine is a 350 ? As the OP mentions the engine is not original...it may just have the small port 2 barrel manifold bolted on... ![]() ![]() ![]() ![]()
#13 | |
Old member
![]() ![]() Here are a few pictures of it.
#14 |
So it got upgraded to the super rare Corvette option!
68' with no bells or whistles unless I add'em. |
#15 |
Old member
Correct!
#16 |
i have often wondered what all those old corvette are running for motors now that they have all been pulled and put in everything else
#17 |
As mentioned by a previous post, timing or even a broke exhaust rocker arm/valve spring. Reason.....u said it backfired when u let off of it. If truck started ok and idled ok would have 2 b a small vacuum leak. A big 1 would show by a bad idle. Due to back fire being when u let up, loose manifold or something n the rocker arm exhaust valve. If u are gonna swap it for a 4 barrel, u may want to pull those valve covers and have a look at all of them . good luck andy.
#18 |
I had one on the 305 I took out of my Blazer when I began stripping it out. Late 70's or 80's. Mine had an egr valve on the intake. Does yours Andy?
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
#19 |
Moderator
Ahhh! The old Corvette 350 situation.....
1/ Corvettes with V8 engines never came with a 2 bbl carb 2/ The intake manifold looks like a 307 manifold....small port runners 3/ If you can, find the engine number, passenger side front of block on a pad level with where block meets head 4/ If you can, post a pic of the front face of the drivers side head showing the casting blocks 5/ Drivers side back of engine is a cast in number...post the number and we can identify the engine for you
#20 | |
Old member
No EGR valve on mine. I got her running as good as she ever has ran guy's. The vacuum hose off the PVC valve where it goes into the motor was maybe 2 threads deep. There where no clamps on either end but there is now. It took me a while because I kept thinking it was the carburetor leaking. Got almost 15 lbs of vacuum on my gauge at idle setting the mixture screws. I set the RPM's a little high but think I can lower them just a bit more with the throttle screw.
#21 |
Now I can tell, that IS a Vette Motor!
#22 | |
I am sure you can find the correct gasket and studs and go from there. I bought this screwy Dodge Dart a while back with the Slant Six. Went to do a oil change and tuneup leaned on the air cleaner and found the whole thing tilting. Took the housing off to find the top of the carb barely had 2 screws holding the whole thing togetether. Put the proper screws back in it after the oil change/tuneup and it ran no better. |
#23 | |
Moderator
#24 |
Moderator
Sadly so many fall for the old "its a Corvette engine".....
#25 |
Unfortunately, I did sell it for next to nothing. Should have kept it as it was a 2 door.
Dodge was a sore subject in the household as Gramps took early retirement when Iacocca took over. As with anything, someone is probably turning it into a 10K rig. Yea, that 6 always fired, never let me down no matter what was happening. |
| Bookmarks |
