Old 10-27-2019, 10:15 PM   #1
chewychevy67
72 only big block clam shell mounts with a small block?
Anyone used a small block with 72 only clamshell mounts? Not the 73 up ones only asking about the 72 style with one hump on the brackets. Does the small block sit where its supposed to or is it higher or lower? I would like to go that route but don't want to mess with relocating transmission brackets or have fan shroud issues. Also I have a 67 frame so if you have done this on a 67 do the frame rails need to be shaved off? Pictures would benifit me alot if you have. Thanks.
chewychevy67 is offline   Reply With Quote
Old 10-27-2019, 10:25 PM   #2
chewychevy67
Re: 72 only big block clam shell mounts with a small block?
And do you have ramhorn manifolds with them or do they hit? I would think not but doesn't hurt to ask
Old 10-27-2019, 10:56 PM   #3
chewychevy67
Never mind. I got my answer. The 67 frame needs to be notched to fit the 72 only mounts. http://www.classicheartbeat.com/panel_4.htm
