![]() Join Date: Aug 2004
Clamshell style motor mount swap; Square body parts
$150 shipped in lower 48, $120 local
I was going to run this setup with an L31 Vortec small block but changed plans. It is a set of square body frame stands 2 new motor mounts 2 sets of block brackets; one tall set and one short set All the used parts were blasted, primed, and painted chassis semigloss The new mounts were primed and painted chassis semigloss When I mocked this up in my frame, it measured out nicely. I got the 2 different height block cups so I had some options for engine height/placement, and could maybe avoid making the oblong holes. Here's the FAQ on how to do this; http://67-72chevytrucks.com/vboard/s...ghlight=mounts
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 10-28-2019 at 09:27 PM. |
Re: Clamshell style motor mount swap; Square body parts
Pics
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
More
And here is the shot when I took my measurements. I tossed those mounts, the ones I’m selling are new.
![]() Join Date: Dec 2009
I will take it.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Sold!
PM sent
Money sent.
Thanks .
Received mounts.
Great deal. Nice Thanks .
You’re welcome. Hope they work well for you.
I know they will.
I have a few Cross-members to (test-Fit) work with. I also have been thru the different Clam Shell issues in other projects. You have done the (leg) work. I noticed that. So I know ![]() They will save me some time. Thanks .
