10-29-2019, 02:47 PM | #1 |
What are these parts
Ughh... I lost track of where these two brackets (A & B) go back on my 1979 Blazer. I had them in a bin next to all the gas pedal assembly parts (that is the larger bracket to the left) so I figure they are part of the pedal assembly or nearby. Can anyone point out where these should go?
10-29-2019, 06:12 PM | #2 |
Re: What are these parts
a = brake rod to brake pedal safety tab . bolts to brake pedal arm to cover rod pin so if the clip comes out the rod wont fall off and no brakes .
b = if i recall is the little tab the steering column sadwiches in place to the dash frame support and a little hex head screw holds the dash to it to hold it from flopping .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
10-30-2019, 11:53 PM | #3 |
Fantastic. Thank-you sweetk30
11-02-2019, 08:23 PM | #4 |
I got the brake safety tab in place (A) but still couldn't figure out where bracket (B) goes.
The tongue on bracket B has a small screw hole on it so it looks like a brace as you described it but I can't figure out the location. |
11-03-2019, 02:18 PM | #5 |
sandwiches between the inner dash / brake pedal frame and pedal assembly and then the steering column bolt up to it . sorry i dont have a install pic but here is the dash with the right side screw and tab out . notice the hex screw on left and hole open right . hope this gives you a idea .
11-09-2019, 04:55 PM | #6 |
Ah, yeah, thanks for the picture. Figured it out. Thanks again!
