10-29-2019, 04:17 PM | #1 |
Straight 6 to V8, wire harness ?
Well I'm taken out the original 1967 six and putting in a 1967 327 four barrel, keeping the manual choke. My question is do I need a V8 harness. No AC , plan jane.
I'm pretty sure I got all the other parts but hey chime in maybe I don't. Thanks Nick. |
10-29-2019, 04:27 PM | #2 |
Re: Straight 6 to V8, wire harness ?
Engine harness wiring harness as far as diagram, pinout is the same 6 cyl, v8, Gauges or no gauges.
Yellow, coil, stsrter relay terminal Green, temp sender, guages or not Brown white stripe, if used, tcs Tan, brake warning switch Purple, starter I dont think i missed anything, if i did, you can see its all the same just different lengths and sometimes terminal type. For example, i think temp warning lamp for no guages has a different terminal and location than guages but still uses the green wire in the same spot on the fuse panel connector. |
10-29-2019, 05:41 PM | #3 |
Thanks randy500, I failed to ask but you happen to mention , there's a difference in length, so that means I'll need a V8 harness and or splice and lenghten my original L6 wires. I hope I'm making sense , lol
Thanks again Nick |
10-29-2019, 08:07 PM | #4 |
Old member
The only thing I know is you may have to make some of the leads longer as Randy said. I'm fixing to do the same thing but with HEI built into the old 6 wiring and internal regulator also.
I have pulled it all out of the truck and have it cleaned up ready to start back but I have some mods I plan on it, here my link with what I'm doing. Going from 3 speed to auto so adding NSS also going to be putting AC in it some time. Radio, amps. I'm think about a early 80's V-8 truck to get the harness out of it. Are the link at the end of my thread with the $99.99 kit. https://67-72chevytrucks.com/vboard/...95#post8618195
10-29-2019, 09:32 PM | #5 | |
The starter is in the same side, the coil is further away from the firewall I dont remember the location of the temp sensor on a 6cyl, if its in front then the wire should be long enough. You will probably have to untape the harness, route the wires then retape it. |
10-29-2019, 09:39 PM | #6 |
Old member
Temp senor is in the front drivers side of the 6 cylinder on mine. You can see it behind the fuel filter. Second picture it's in the shadow.
