10-31-2019, 12:54 PM | #1 |
Head lights issue
Just bought a 6 cylinder 1969 C10 and it’s on it’s way to Sweden now.
The seller told me that the headlights doesn’t work. He’s been driving the truck with only the parking lights on for many years. So what would I look for at first? The ground or ? Posted via Mobile Device |
10-31-2019, 12:58 PM | #2 |
Re: Head lights issue
Could be grounds,headlight switch or dimmer switch.
68' with no bells or whistles unless I add'em. |
10-31-2019, 01:09 PM | #3 |
20' Daredevil (Ret)
^^^ Yeah, a basic VOM or just a simple test light will work. Check grounds at the headlamp connectors, check voltage from the fuse block to the HL switch to the dimmer switch (these are prone to failure) and then to the connectors.
10-31-2019, 01:25 PM | #4 | |
Great 👍 Posted via Mobile Device |
10-31-2019, 01:31 PM | #5 |
Had same issues. The dimmer switch, probably the dimmer switch. After many hrs, it was that darn dimmer switch...
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
10-31-2019, 01:34 PM | #6 |
10-31-2019, 06:40 PM | #7 |
And then an upgrade to headlight relays would be good - made a world of difference for mine. They can be made or purchased. My kit was very easy to install.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
10-31-2019, 07:57 PM | #8 |
Moderator
Make sure the headlight units themselves work first then check grounds, then check power supply to the lights when the switch is on....
Check fuses
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
10-31-2019, 10:18 PM | #9 |
Old member
I just pulled a wiring harness out of my daughters 68 step. There are head light ground wires on both lights to the radiator support. Then I would check the lt- blue wire to dimmer switch it feeds it from the headlight switch. See if it has power. If not it's in the h/L switch are the red wire feeding it which is in the bundle of wires under the dash. It's a factory solder joint that is just taped up in the harness.
If you do have power then hook it back to the dimmer switch and see if it's working. Either way that's where I would start looking.
11-01-2019, 12:22 AM | #10 |
[QUOTE=OregonNed;8619337]And then an upgrade to headlight relays would be good - made a world of difference for mine. They can be made or purchased. My kit was very easy to install.
I also bought 28 Circuit Classic-Plus Customizable 1967-72 GMC / Pickup Truck Chassis Harness P/N 10206. Hopefully there some relays in it. Thanks Posted via Mobile Device |
11-01-2019, 12:24 AM | #11 | |
