11-01-2019, 04:37 PM | #1 |
1967 Exterior Door Handles Now Available
Long needed and finally available 1967 Specific Exterior door handles.
Part # 19891361-2 1967 Exterior Outer Door Handle Kit. Includes both left & right exterior door handle's and handle & lock gaskets, and 4-screws required to install both handles. Just like the original 1967 exterior door handles these use a bolt that threads straight into the handle, unlike the 68-72 that threads in at a angle. High quality reproduction of originals with polished chrome finish. Reproduction doors should use 1968-72 version as all 67-72 are made for use with 68-72 exterior door handles. Found on the following page of our website https://gmcpauls.com/Exterior.htm Paul Jr @ GMCPauls Last edited by GMCPaul; 11-01-2019 at 05:17 PM. |
11-01-2019, 07:29 PM | #2 |
Old member
Re: 1967 Exterior Door Handles Now Available
Those look nice sir! I will have to check on mine and see which ones I have. I have several broken set's to fix.
11-02-2019, 02:26 PM | #3 |
Great news. Way back when I figured out 67's had different door handles you could still find them NOS. Nice to have a spare set now.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
