Old 12-04-2003, 07:28 PM   #1
special70gmc
special70gmc's Avatar
need tire help please
im getting really close to needing new tires for the truck, since the drop i cant move it cause the 31'' tire rub on the fenders.ill attach a pic of the height w/a 235/75 and the 31'' and i would like a size recomendation, also what does the first # ex.235 and the secc ex. 75 mean wjen your dealig tires? thanks -kyle
ps heres a cool link http://www.project33.com/tiresize.cfm
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 12-04-2003, 07:29 PM   #2
special70gmc
235/75r
1958 belair 2door
Old 12-04-2003, 07:32 PM   #3
redbowtie
The first number is the width in mm., the second is a percentage of the width in height...
235 mm's wide, the sidewall is 75% of that tall...
redbowtie is offline   Reply With Quote
Old 12-04-2003, 07:58 PM   #4
Try this it'll give you a visual
http://www.toolmandesign.com/tireapps/tirecalc.html
If you are running ralleys, the 235-75 is about an inch shorter than the 31x150 tire. A 255x70 is about same hiegth as the 235-75...if you need more clearance a 275x60 is about an inch shorter than the 235, but the width may cause problems. I wouldn't go smaller than a 255 x60 for a tire...but that is me.
Old 12-04-2003, 08:04 PM   #5
lukecp
Formerly yellow72custom
lukecp's Avatar
I think these trucks look great with 255/60-15 tires in front (on a 15x8 wheel) and 275/60-15 tires on the back (on either a 15x8 or 15x10). I've got some pics of my truck with 15x8's all around and 255/60's all around on the website in my signature
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 12-04-2003, 08:06 PM   #6
lukecp
lukecp's Avatar
Oh, BTW, 75 is the aspect ratio of the tire. It means that the sidewall is 75% of the height of the tire tread with.....so the lower the aspect ratio, the shorter the sidewall
Old 12-04-2003, 08:14 PM   #7
special70gmc
well the truck is dropped 4.5 in the front w/ spindals + springs
thanks alot -kyle
1958 belair 2door
