'71 C 10 accelerator cable
While exiting freeway at 65 mph yesterday throttle was stuck wide open and was able to avoid stopped traffic barely, after pulling over, manually got idle down but don't know if this is cable or carb linkage problem and what I should do to fix it. Thanks for any help.
![]() Join Date: Mar 2003
Re: '71 C 10 accelerator cable
Unsnap the cable from the linkage and see if it is smooth acting or possibly frayed making it stick. If smooth, start looking at the carb. Floor mat inside the cab?
I'll go out and check that right away, do know it is not carpet or anything hanging up inside cab
Found it...was looking on wrong side, piece of choke linkage broke off and was getting caught in carb linkage. The red plastic "L" shaped piece behind choke (Why plastic?)
Old member
I would add another spring to the front of the throttle to pull it back down to idle also. May want to take the one you have and reverse it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
