Old 11-02-2019, 09:08 PM   #1
weim55
Where is the Rear Brake Adjustment Window 69 C20 ??
Went to remove the hub-brake drum assembly on my '69 C20 coil spring HO52. Going to have to backoff the brake adjustment to get the assembly removed. There is no brake adjustment window anywhere, none on the backing plate, none on the brake drum. No knockout plugs anywhere either. Wondering if the brake drums are replacements and the originals had the windows?? Would one of you possibly have an image of an original and the window location?? I'll just cut a window if I know the location........
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 11-02-2019, 11:03 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Where is the Rear Brake Adjustment Window 69 C20 ??
My '72 K20 was the same. We had to fight to get the shoes off, then drill holes in the backing plates for future access to the adjusters. The holes have rubber plugs in them now.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-03-2019, 12:21 AM   #3
FirstOwner69
FirstOwner69's Avatar
Here's a picture of mine, also a '69 C20 coil spring H052. I don't recall ever replacing the drums, but to be sure I'd need to check the receipt file. The truck has 119,XXX miles and most miles were highway.
Hope this helps.
Jim
FirstOwner69 is offline   Reply With Quote
Old 11-03-2019, 12:29 AM   #4
weim55
Hope this helps.
Jim
That's perfect, thank you! Wondering if the knockouts are there and I just can't see 'em with my old eyes (laughs...) I'll take a close look tomorrow and if there are no knock outs I'll just cut a couple adjustment windows to duplicate yours.
Old 11-03-2019, 12:46 AM   #5
FirstOwner69
Glad I could help.
Jim
Old 11-03-2019, 01:07 AM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Good luck with it Steve, I hope you find some knockouts. Mine absolutely did not have them.
- Mike -
RIP El Jay
Old 11-03-2019, 08:13 PM   #7
RustyPile
RustyPile's Avatar
I can't really tell, could be just a "pattern" in the dirt.. Is that a knock out plug at about the 9:00 position??
RustyPile is offline   Reply With Quote
Old 11-04-2019, 12:51 AM   #8
weim55
Sure enough, you are correct! Used a wire brush and finally found it! Thanks for the help guys!
Old 11-04-2019, 07:45 AM   #9
jaros44sr
jaros44sr's Avatar
don't expect that plug to come out easy mine gave up quite a fight, mine was really in there
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-04-2019, 10:36 AM   #10
LockDoc
The Older Generation
LockDoc's Avatar
It isn't really a plug because it isn't cut all the way through. They just mark the location.
LockDoc
Leon
Old 11-04-2019, 12:04 PM   #11
weim55
You were correct, those plugs would positively not come out! Had do use a torch on both of them to get them out, only to find both drums were junk. Now I’m finding how difficult it is to find rear drums for a 69 HO52 ........
Old 11-04-2019, 11:01 PM   #12
Chevys4life
Steve............try this place in California for your rear drums and brake components. Go to www.inlinetube.com and take a look.
Chevys4life is offline   Reply With Quote
Old 11-05-2019, 07:37 AM   #13
jaros44sr
jaros44sr's Avatar
I bought mine (1/2 ton from rock auto), returned 3 sets b/c they were cracked, b/f I got a good set
SAFETY FIRST
AS usual, off topic
Jim
