11-03-2019, 05:52 PM | #1 |
Fuel line from carb to fuel pump?
Can you buy replacement hard lines or is there an alternative? Mine is striped and will not seal
11-03-2019, 06:05 PM | #2 |
Re: Fuel line from carb to fuel pump?
Yes, I have one from Amazon, pre-bent ? $24 two yrs ago
11-03-2019, 06:54 PM | #3 |
Ok I will search it up
11-03-2019, 06:56 PM | #4 |
Yeah, sorry I didn't provide a link, but a simple search should do the trick
11-03-2019, 07:22 PM | #5 |
No luck on Amazon
11-03-2019, 07:23 PM | #6 |
I found one on Summit but it says it’s for a 71/72. My truck is a 70.
11-03-2019, 07:26 PM | #7 |
11-03-2019, 07:41 PM | #8 |
Inline Tube maybe?
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White 1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White. |
11-03-2019, 07:44 PM | #9 |
11-03-2019, 08:16 PM | #10 |
Here's the package, I guess they get it from the same place as Summit
11-03-2019, 08:28 PM | #11 |
Thanks for the confirmation. That one worked with no issues. I also found one that was specific to 67 to 70. I can’t imagine there any different from 67 to 72
11-03-2019, 08:29 PM | #12 |
11-03-2019, 09:36 PM | #13 | |
Hard to strip a flare fitting. The seal is on the flare seat, not the threads. You might need a new fitting on the carb and pump too. You got a pic of where it was leaking. |
11-03-2019, 10:06 PM | #14 |
I can post them tomorrow. It’s leaking where the hard line meets the fuel pump. Fuel pump is new. But on the hard line is striped. Some of the threads look flat. Maybe it’s not sitting properly but it feels correct. I’ve tried three times.
11-03-2019, 10:09 PM | #15 |
Does it snug up tight or pop loose when you tighten it?
11-03-2019, 10:33 PM | #16 |
It snugs up tight
11-03-2019, 10:53 PM | #17 |
Good!
It’s fixable. Try this. You need to mate the flare tubing to the seat. You need to induce enough heat (minuscule)to move a tiny bit of the metal surfaces to make them seal. It’s the tighten loosen thing. Tighten the tube nut just snug, loosen it off a 1/4 turn. Tighten again but a bit snugger, loosen again. Do that about 6 times and you’ll move a little metal and mate the surfaces. Should stop your leak. If not try another 6 times. This method works extremely well when seating new fittings. Usually the only time it doesn’t work is if the flare is cracked. |
11-03-2019, 11:29 PM | #18 |
Thank you. I’ll try this tomorrow. I’m super discouraged and tired of dealing with fuel. I’d rather be coverage in oil!
11-05-2019, 08:47 AM | #19 |
How did you make out?
1968 C-20 CST Vermillion http://imageevent.com/happy_dan/dantoys/68c20 2019 Silverado 2012 Camaro ZL1 |
11-10-2019, 12:44 PM | #20 |
The flange was slightly damage so I had to replace the hardline. Thanks for the help on this.
