Old 11-04-2019, 10:27 AM   #1
phlegm
Still Green but learning
phlegm's Avatar
AC Hose swap? Opinions welcome
I have been posting a lot more as I am finally getting my C10 back in shape. Its an AC Cab. Since I am swapping the gas tank (see other thread) I thought while it was stuck in the garage I would clear coat some rusty spots and freshen up the Dash Gauges. I did them last night with orange paint and wipe down. I am short an LED or two and have a couple of sockets that arent working right so waiting on those to come in tomorrow.
My question is, while I have the Dash out should I go ahead and replace the vent hoses? and if so Plastic or cloth covered?
I hear some rattling in them when the fan is on but looking at them they look to be in decent shape, and I hear it can be a little trying. My other thought was to run the fan and get a shop vac or two out and put them up to the vents while the trash is being pushed around.
Any ideas? I know someone has been in this spot.
thanks!
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 11-04-2019, 10:31 AM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: AC Hose swap? Opinions welcome
Most times it's inside the box on the passenger side in the fan area also on the outside behind the passenger side hood hinge. It's a little time consuming job but it can be done.
If the truck has sat for a long time best suggestion is pull the boxes a part and clean them out good.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-04-2019, 12:20 PM   #3
phlegm
phlegm's Avatar
Great advice, thanks!
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
