Old 11-04-2019, 04:42 PM   #1
Kevinn
Dash lights help
I have 1970 c10 396 bbc 1/2 ton and was trying to figure out why my dash lights dont work and my fuel gauge and I stumbled on this black wire with a blub not connected to anything and was wondering if need to be connected somewhere and if that's the cause why my gauge lights dont work. Also notice this grey wire with something on it dont know its for.I'll appreciate the feedback. P.s I'm new to this its my first car and learning bout this truck.
Kevinn is offline   Reply With Quote
Old 11-04-2019, 05:38 PM   #2
DA71Grande
DA71Grande's Avatar
Re: Dash lights help
The first one is the shift indicator bulb it plugs into the back of the cluster the second pic looks like it’s for your heater control bulb
Doug
71 Sierra Grande C25
16 Sierra 2500HD All Terrain
23 Chevy Tahoe Z71
https://paypal.me/digdug7131?locale.x=en_US
DA71Grande is offline   Reply With Quote
Old 11-04-2019, 05:52 PM   #3
randy500
Your dash lights probably don't work because the headlights switch is probably bad, there is a variable resistor (would wire) visible where it mounts, it provides dash light dimmer function, they go bad and or have bad spots.
Fuel gauge is probably the sending unit or float.
If the gauge goes to or sits at 3 o clock, the gauge probably has power and ground.
The tan fuel gauge wire at the fuse box upper right could have come loose or the wire on the sending unit could have come loose. Unhooking it and or plugging it in should make the gauge move, if it goes to empty when connected and you know its not empty then the float is probably bad.
randy500 is offline   Reply With Quote
Old 11-04-2019, 06:45 PM   #4
Kevinn
I disconnected the tan wire and the fuel gauge doesnt move at all. I replaced the fuel gauge and going to see if it moves when I disconnect the tan wire. You could be right my light switch acts up sometimes doesnt work or cab light goes on without touching switch.
Old 11-04-2019, 07:22 PM   #5
randy500
Why didn't you check for power and ground?
There is a fuse, cluster feed, upper right,
Does the temp gauge work? It powers that too.
Old 11-05-2019, 12:27 AM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Your first picture is the fiber optic cable. The picture below shows where it installs in the back of the cluster. Insert it into the hole and turn it 1/4 turn to the right. Make sure it is seated all the way in the hole before you turn it.
The heater control bulb holder snaps into the hole in the back of the heater control assembly. (pic 2)
LockDoc
Leon
Old 11-05-2019, 07:55 AM   #7
rpmerf
rpmerf's Avatar
http://outintheshop.com/faq/wiring/w...s/image002.jpg
http://outintheshop.com/faq/wiring/w...s/image003.jpg
I would start out with a test light or multimeter and work your way from one end to the other. Make sure you have power and ground at the connector for the cluster. I don't know the terminals on the gauge, but you should be able to find that here somewhere.
Cluster lights circuit:
bulbs
printed circuit board on the back of the cluster
20 gauge Gray wire
fuse block
16 gauge Dark Green
Light switch
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 11-06-2019, 01:17 PM   #8
Kevinn
None of my gauges work except speedo and oil.
Old 11-06-2019, 02:22 PM   #9
phlegm
Still Green but learning
phlegm's Avatar
those two run off of other cables and not necessarily the circuit board dont they? Sound like the wiring harness or ckt board may be shot. But I dont have a gauge cluster, so not sure.
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
