![]() Join Date: Feb 2019
Find My Shift Boot..
Ordered a shift Boot from LMC, and it doesn't fit, its too round and mine is more square. and the holes dont line up on the round one.
Anyone know where I can find one to fit? Original is on the right.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
Re: Find My Shift Boot..
I may be wrong but as far as I am aware of the shift boots only came round. There were two variations of the boot, one of them being like the new one in your picture. The other being mounted flat to the hump but still round. It appears someone has cut their own hole in the floor and used a nonfactory boot to cover the hole.
1978 SWB cheyenne A/C, power steering/brakes, 305, Tach, Gauges 1972 SWB Custom 10, gauges, cammed LQ9, M22 ![]() |
![]() ![]() Join Date: Sep 2008
I checked GMC Paul's website and they list five different boots.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
OK, thanks,
Even if it is a non stock boot, I would like to find a replacement. Or I can make a Custom Leather boot,... Hmmm, might just do that..
I find GMC Pauls a little hard to navigate.. Do they even have a search feature?
Is your trans a NP435? Some Ford sites might have that boot.
![]() Join Date: Dec 1999
Fifth item down on this page:
https://gmcpauls.com/rubber&ws1.htm No picture, $20, says to specify which one you want. |
GM used the New Process 435 Transmission in limited C20 models, Seems like I have one, and they use a different shift boot.
The shift boot is formed to be taller that the standard 4 speed boot but is formed to fit the floor correctly. Any Idea where I can find one? GMC Pauls does not have a picture of the boots available.
#9 | |
The Older Generation
Paul Jr frequents this site. Send him a PM and have him look at your picture. He should be able to tell you if they have one. LockDoc
![]() Join Date: Dec 2012
I think a rustic leather boot would look great...
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
Good Idea, I will try that.
Here is one of his threads if you can't find him.
http://67-72chevytrucks.com/vboard/s...d.php?t=791561 LockDoc
#13 |
Got an email from Sky at GMC Pauls, They don't have the Original boot for my truck but they were very helpful, Still looking.
#14 |
Go Pack Go!
Yours if not original to your truck. You can clearly see the rough cut some past owner did to open the round hole bigger and square.
#15 |
So looking on the original Build Sheet, the truck came with a M28 HD Trans.
SPID says HD 4 SPD CR Trans Somewhere it was changed to a NP435. Still trying to find the original boot for the NP435.
#16 | |
You might check some of these out to see if one will work. https://www.summitracing.com/search/...e-shape/square LockDoc
#17 |
Take a look at the Speedway motors site. They had several square and rectangular Lokar boots shown.
Smitty '71 Short Fleetside Spring Valley, Ca. |
#18 |
Think I may have found one that will work,
Dorman 924-5405 ![]()
#19 |
The NP 435 is the close ratio trans. The M20 SM465 is wide ratio trans.
#20 |
#21 |
Does your SPID & Build Sheet look like these? If so, your 435 may very well be from the factory. Mine is. I found a boot years ago, for a Ford. Still looking for the site and/or a receipt for you. Hope the new one works out.
#22 |
Yes, My build sheet and SPID are intact and in excellent shape.
Just like yours it says HD 4 SPD CR Trans.
#23 |
Received the Dorman Shift boot today, this thing is STOUT, twice as thick.. Made for a Kenworth Truck..
Fits great with a little elbow grease.. Retainer ring. Boot Retainer stamp.
#24 |
Good deal! Glad it will work for you. LockDoc
#25 |
![]() Join Date: Apr 2017
I know it's late, but I just got my transmission back in and dug out my shift boot. Here are some pics of the correct shift boot for an NP435 transmission. It's not in the best shape, but you get the idea.
I hope it at least helps someone else in the future!
1968 GMC C2500 Long Bed Fleetside Last edited by Willys_MB; 11-08-2019 at 04:09 PM. Reason: grammar |
