11-04-2019, 10:58 PM | #1 |
Z bar pivot ball broke. Common?
Went on a slow cruise to scout for deer and while I was out and about, my clutch pedal got easier to push. Made a pop sound and two pushes later, nothing. Now my clutch pedal has always been pretty stiff and I had the z bar off to clean it and put new grease in it. But the pivot ball that threads into the engine block broke off flush with the block. Now I have to get it out of there and replace, which is no big deal, but has anyone else ever had this happen? Any idea why this happened? Thanks everyone!
11-04-2019, 11:04 PM | #2 |
All about them K’s
Re: Z bar pivot ball broke. Common?
I’ve had to do this job before, I got lucky and it was easy to fish the threaded part out of the block. I think it breaks just because it’s a stressed part especially after 50+ years.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
11-04-2019, 11:21 PM | #3 |
I had an arm break off the Z bar. It was a Big Block 402 3OTT truck.
11-05-2019, 11:34 AM | #4 |
I broke one about 20 years ago when my 4x4 was still a three on the tree.
I was just cresting the top of the bridge out of Red Wing, MN to sneak back to my MN house via western Wisconsin. At the top of the bridge I pushed in the clutch and BANG! No more clutch. I coasted to the bottom of the bridge on the Wisconsin side. I had AAA at the time as I was fishing a lot of bass tournaments - which is why I was down there at the time. I called AAA. I could urinate on MN from where my truck was but because I was on the Wisconsin side they had to call a truck to come 10 miles from the nearest po-dunk Wisconsin village verses a larger town, Red Wing in my rear-view mirror. After some choice words I convinced the good people of AAA to have me pulled a few feet back to MN where a shop replaced the ball stud. I sure don't miss the jam-o-matic three on the tree. Especially at the boat ramp. It probably was simply fatigued after 50 years of you and others pushing on it.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
11-06-2019, 12:37 AM | #5 |
I have broken arms off the Z-bars on both my '68 C/10 Stepside w/292 L6, and my '71 GMC Jimmy K/1500 4x4 w/350 V8.
Both Z-bars had been heated and the arms bent, slightly, to clear headers. On the V8 in a 4X4, the pivot stud seems pretty stout, and is threaded into the side of the block. The L6 set-up [on a C/10] had a stud set in a steel strap that's bolted to the block. The end of the stud is bucked down [with an air hammer?] and looks like it could pop under severe stress.
11-06-2019, 12:50 AM | #6 |
Yes, Broke on on my C20, Squirt some grease in there..
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
11-06-2019, 08:33 PM | #7 |
Well I took the z bar out and the broken stud backed right out with the end of my index finger. I was happy about that! Ordered the new ball stud and felts today from Classic Parts. I will be back in business hopefully soon! I will be sure to get plenty of grease in there when I get it back together. Thanks to all for your input and support!!!
