Old 11-05-2019, 09:59 PM   #1
Andy4639
Old member
Andy4639's Avatar
Cluster freshening up...
I'm starting on my daughter's dash cluster and got to wondering. Why did Chevy use this green color on almost every Chevy I have ever took a part it's this same color. There has to be a reason. Even so I'm going with a silver inside to hopefully make the old 194 bulbs look brighter at night.
I painted the needles last night and tonight decided to take it all part and clean it up and brighten it up I hope. May even go with some LED dash lights.
Any good links on LED lights for these cluster? With part numbers and if they will work with the dimmer.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-05-2019, 10:06 PM   #2
firedemon
Re: Cluster freshening up...
I used chrome paint on the back and kept the green on the front used the led bulbs made a huge difference in brightness and still keeps the green
firedemon is offline   Reply With Quote
Old 11-05-2019, 10:33 PM   #3
Andy4639
Old member
Andy4639's Avatar
Question Re: Cluster freshening up...
Do your LED's dim when you dim the lights?
Do you have a link where you got them?
Old 11-05-2019, 11:19 PM   #4
phlegm
Still Green but learning
phlegm's Avatar
I just finished doing this to mine have not completely reinstalled it yet what was able to get these pictures. They did a great job they do down but they're not as responsive as regular light bulbs are. I'm not sure if that's the case with all of them. But you do have to turn it almost off and they go down a level or two. I don't know how but I bought two packs and I never could figure out if it was my socket oh, the LED, or the circuit board that wasn't driving but in a couple of spots I had to switch LEDs and switch sockets and move stuff around to get it all to work. But it works out now then I think it looks great. I stay Green what these LEDs. And I did not get the brightest LED I can find either because to me there just wasn't the point I don't want to be blinded going down the road.
https://www.amazon.com/gp/aw/d/B07T6...?ie=UTF8&psc=1
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 11-06-2019, 12:03 AM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: Cluster freshening up...
Thanks,
I ordered them. They should be here Friday and I can get it put back together and check them out.
Old 11-06-2019, 10:16 PM   #6
palallin
The muted green keeps the glare of the lights from overwhelming the driver's night vision.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 11-06-2019, 11:02 PM   #7
Andy4639
Old member
Andy4639's Avatar
Maybe it will be like driving with a HUD system in the truck!
Old 11-06-2019, 11:57 PM   #8
toolboxchev
Most likely that yet I also think they may have been using something like what was utilized on war planes. I think its a zinc,phoshate style of paint.
toolboxchev is offline   Reply With Quote
Old 11-07-2019, 09:27 AM   #9
volksworld
think they were going for the color of the old luminescent radium watch dials and aircraft instruments...to imitate "cutting edge atomic age technology"...
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 11-07-2019, 09:54 AM   #10
BigBird05
I just got some LED's from a junk yard late model chevy cluster. Has anybody used these yet? How do they look?
BigBird05 is offline   Reply With Quote
Old 11-07-2019, 10:06 AM   #11
rpmerf
rpmerf's Avatar
Be aware that LEDs are are diodes and can only be installed in 1 direction. If you switch up positive and negative, they will not work. Incandescent bulbs can be installed in either direction.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 11-07-2019, 10:12 AM   #12
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Cluster freshening up...
volksworld,
I hadn't thought of that before, that maybe true since that was a big thing back in the day.
Well I have the panels painted the chrome spray paint for now. I'm going to clean the lens up good and repaint the dash outer rim with the chrome paint as well and see how it looks then decide if I need to buy a new one.
Hope it want be so bright it blinds her when driving it. I can always go back to the regular bulbs.
Old 11-07-2019, 10:15 AM   #13
phlegm
phlegm's Avatar
Thats kinda why I stayed green and got the lower powred LEDs. Cant wait to see the update!
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 11-07-2019, 10:21 AM   #14
Andy4639
Old member
Andy4639's Avatar
I have a old plugin out of a old truck that I'll hook the cluster up before installing and put power to the lights and check them out, stay tuned. Yes LED lights are polarity-sensitive so they have to be wired right are they want come on. This is why I plan to check them before installing the dash.
BigBird05
Do you have pictures of them? Do they have the same connector as our truck, the ones I've seen have the mini connectors. They are white instead of black.
Old 11-07-2019, 11:25 AM   #15
OregonNed
OregonNed's Avatar
I like this answer!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 11-07-2019, 01:41 PM   #16
Andy4639
Old member
Andy4639's Avatar
Temporary have the dash together with a old cluster dash I had. Waiting on the one I'm gonna use to dry. This was with the incandescent bulbs also. I did a mod to the cluster also to use pipe foam cover for the lens pads and it blocks off the light shining places it doesn't need to.
I used the GM converter my dad gave me to light it up.
https://www.youtube.com/watch?v=29t-_jFCiqg
Old 11-07-2019, 01:55 PM   #17
phlegm
phlegm's Avatar
yea I had bleed over from the gas gauge to the rt turn signal on mine, but being the 3 gauge cluster it was a little easier for me just to isolate that one side. I used some contact cement and a little bit of the same color green felt as the paint on the inside of the cluster.... worked out great so far. Ill post mine buttoned up when I get there.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 11-07-2019, 02:22 PM   #18
randy.powell
168 bulbs are a little brighter than the 194 bulbs.
Randy
randy.powell is offline   Reply With Quote
Old 11-07-2019, 03:21 PM   #19
Andy4639
Old member
Andy4639's Avatar
Here it is all done. The bulbs showed up right after I posted the other pictures.
I think it turned out great though. Video and pictures. Look at the last one. It where I placed the pipe wrap to cushion the lens and block off the light bleeding through.
https://www.youtube.com/watch?v=DPXrJSpJq5U
Old 11-07-2019, 03:23 PM   #20
phlegm
phlegm's Avatar
Looks Great
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 11-07-2019, 06:30 PM   #21
Andy4639
Old member
Andy4639's Avatar
Well after a few test here is the lights dimming down. I hooked all of them up to do this to show it better.
I will be taking the cluster out of the Ramp truck and adding these to it as well.
https://www.youtube.com/watch?v=FYEE6VDmwo0
Old 11-07-2019, 07:24 PM   #22
71gmcC15
71gmcC15's Avatar
I did the same thing a couple years ago but only painted the needles. Also kept the old bulbs. It maches my pickup well. Not to noticeable that I did any thing but made it look better
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 11-07-2019, 09:23 PM   #23
Toro
Toro's Avatar
Andy, what chrome paint did you use?
Also does anybody know what paint matches the original green?
Toro is offline   Reply With Quote
Old 11-08-2019, 09:09 AM   #24
Andy4639
Old member
Andy4639's Avatar
The paint is Wal mart brand I had here at the house. It turned out OK but it had a few spots in it. I took red scotchpad to it before I painted it to. I don't understand why it soted like it did though. Not bad for a spray can though.
I can say this about the green. My local paint store can zap it I bet and get dang near perfect color. They did my 64 SS Impala and it's a 100% match up. I may take a old dash to them and see what they come up with.
Here are some pictures of the Impala. I painted the dash, tack cup, steering column and the center console with a can of spray paint.
Old 11-08-2019, 02:04 PM   #25
littlehopper
Great job, this is one of my winter projects.
littlehopper is offline   Reply With Quote
