11-06-2019, 11:11 AM | #1 |
Still Green but learning
Fuel tank removal
I searched the site and cant find an exact answer to my question. Hoping someone with experience can answer, I like to plan these things out makes it easier.
I ordered a new fuel tank and I need to get the existing one out. Inside the cab everything looks pretty straight forward, remove lines unbolt etc... question is do I just pull the tank through the rubber ring on the outside of the truck? I dont want to replace that if I dont have to (which I might since the new one is an market tank). Thanks in advance.
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
11-06-2019, 11:39 AM | #2 | |
Re: Fuel tank removal
Yes, the tank spout should pull through the grommet. If the grommet is old it could be damaged on removal of old tank. If still in good condition spay some lube on the inside of the grommet when installing the new tank. Also the new tank spout may not be in the same location as the old one and some adjusting may need to be done. I use the wooden handle on my hammer insert it into the spout and adjust accordingly........good luck.
Az |
11-06-2019, 11:58 AM | #3 | |
11-06-2019, 11:36 PM | #4 |
Its a Truck Thing......
Wear Gloves......
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
11-06-2019, 11:42 PM | #5 |
And take the filler cap off...
11-06-2019, 11:46 PM | #6 |
I just did this. If you have to buy a new grommet, everyone says to get the one from classic heartbeat. They are pretty cheap, like 13$ shipped. I’d just order one as a back up and save yourself time if you end up needing it.
11-06-2019, 11:46 PM | #7 |
Lol, always. I have cut my fingers enough
11-06-2019, 11:47 PM | #8 |
11-06-2019, 11:48 PM | #9 |
Thx, it's going in tomorrow night so we'll see
11-07-2019, 10:23 AM | #10 |
Do yourself a favor and make sure the tank is drained as much as possible , I thought mine was near empty and wasn't (via the gauge) . The extra weight made it a lot more of a wrestling match than it needed to be .
11-07-2019, 10:32 AM | #11 |
Will do! I also went ahead and pulled the seats.. figured 2 birds with one stone, I am putting in shoulder harnesses so it makes both jobs a lot easier and I was able to vacuum up 48 years of crud while I was at it ( or my son was )
