Brake and other line replacements on a 66- what to get?
Im nearing the point where the lines can go back in and I plan to replace what came off. Ive never done this before so I dont want to screw up and order stuff that doesnt fit or even things I didnt need. Is it best to buy pre bent or bend it up for a newbie? Ive got a tool for the bending I used in the past and I think I could manage the bending..the flaring and hardware parts I have no idea about though. Here is what I have in the pile of replacement parts. I only labeled the transmission cooler lines so Ill need to make sure I have the lines properly identified. In this pic, I think these are all brake lines, but the one to the left has a double line thing going. I have a dual master cylinder but the kits Im finding online on a 66 dont have that, so where should I be looking instead since a conversion had been done before?
Re: Brake and other line replacements on a 66- what to get?
More brake lines
Trans cooler lines
Even the parking brake cables I need to reorder and this is what I had removed before.
Assuming drums all around and single M/C I'd at least change it to dual chamber M/C. Get one from a 67, and from what I understand front line goes to front brakes. Buy a flaring tool and have fun. You will of course need to get some fittings to split the front and back.
If you plan on keeping your original M/C I wouldn't even bother renewing the lines, unless they have rust pitting. |
#6 | |
Moderator
![]() Join Date: Dec 2012
I wouldn't do stainless, do the cunifer lines, they bend super easily (and flare great). That's what I used on mine when I re-did all lines for my dual master.
Moderator
duplicate
grr rural internet, lol |
Thanks Jay, is 3/16 the standard? I did a search for cunifer lines and saw this
https://www.amazon.com/Brake-Line-Un...27330710&psc=1 I also watched this guys video on how to, seems do able! https://www.youtube.com/watch?v=9V9Jg1BORlk Last edited by msg; 11-07-2019 at 07:24 PM. |
![]() ![]() ![]() Join Date: Jan 2018
First pic with the two lines attached together: The line with the rubber hose on each end is the fuel line from the tank to the fuel pump. The other line is the single line that runs back to the rear brakes
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Thanks Christian for helping me sort this all out. Is there a standard size for fuel, brake, and trans? Is 3/16 good for all?
![]() Join Date: Jan 2011
Look at inline tube for a lot of what you need. The have most of it. Depending on what brake upgrades you have done you can use parts from other years. If you are still on all drums a kit for a 67 will get you what you need. For the fuel line you need at least 5/16. I ran 3/8 on mine.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#13 | |
#14 |
![]() Join Date: Nov 2013
if you go with inline tub make sure you tell them on master cyl. 1 or 2 line and were you want union on frame stock is in back just did 1 last week and they sent wrong piping for 1966. k-10...have 66 c10 owned for 50 years same brake lines..if you lived in dallas area i have stock 66 to look at for info.
