11-07-2019, 10:45 PM | #1 |
Need alittle help
I'm looking for the part # for the warning brake light switch. Mine has the single post any help would be appreciated. I installed a new wilwood master cylinder and brake booster and i cant seem to find the part# im looking for.
11-07-2019, 11:54 PM | #2 |
Re: Need alittle help
72 C10 lwb fleetside -stock 350/350 combo |
11-07-2019, 11:58 PM | #3 |
I was going to use the wilwood portioning valve just looking for the correct switch that would screw into it .
11-08-2019, 12:02 AM | #4 |
11-08-2019, 12:08 AM | #5 |
Yeah, but instead of having two wires running off of it because that what the wilwood portioning valve had i need just the switch with one post that i can plug the original plug onto. If there is such a thing
11-08-2019, 12:36 AM | #6 |
This one does have only one wire
11-08-2019, 12:47 AM | #7 |
Yeah thats just the connector and not the switch it's self
11-10-2019, 12:36 AM | #8 |
Old member
I took the switch out and cut the plastic off and filed it down to let the wire connector on mine work. Works just fine.
11-10-2019, 12:47 AM | #9 |
Do you happen to have the part # for that switch your using? That's a good idea
11-10-2019, 10:01 AM | #10 | |
Old member
Sorry, I don't it came in the Proportioning valve when I bought it. I will take a look at it this afternoon and see if I can find a number.
11-10-2019, 10:31 PM | #11 |
You might want to call Wilwood. I bought one of theirs from Summit them and switch was included. Make your you get correct type disk/drum or disk/disk.
https://www.summitracing.com/parts/w...1322/overview/ |
11-10-2019, 10:46 PM | #12 |
This is the one i have manually adjusted looking for the switch that'll thread into that with the single post instead of the two blade types
11-11-2019, 11:42 AM | #13 |
Old member
I think we are talking 2 different things here. The picture you posted is a stop light switch that takes the place of the brake switch under the dash on our trucks.
The one you are wanting is the switch that tells you if there is a problem in the 2 lines which is normally on the Proportioning Valve itself. It only comes on when you have a problem.
11-11-2019, 01:41 PM | #14 | ||
"I ain't nobody, dork."
I agree with Andy... you need to contact Wilwood directly to see if it's even an option for that setup..
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
11-11-2019, 02:33 PM | #15 |
If you have the wildwood Adjustable Proportioning valve, why did you show a drawing of a factory type Combination Valve?
An even better question is, "why is Summit showing a combination valve and calling it a Proportion valve". The Wilwood Proportion Valve is described as, "Proportioning Valve - Combo Knob Description Wilwood’s new Combination Proportioning Valve substantially simplifies mounting, plumbing, wiring and brake proportioning adjustments on vehicles with custom brake systems. It is a Combination Valve in the sense that it serves as a distribution block, a proportion valve and a switch for rear brake lights. You already have the rear brake light switch on your brake pedal. It does not include a Metering Valve or a Brake Failure Warning Switch that are included in a factory type Combination valve. For a relatively stock type truck, you may want the Metering Valve. The metering valve prevents any nose-dive effect at low speeds. For your application I would think a conventional factory type Combination valve would work well. If you have a problem with rear brake lock-up, you could then add a inline adjustable proportioning valve after the Combination Valve to the rear. You would then have two proportion valves in the rear circuit. This would give you adjustability beyond the Combination Valves Fixed Proportioning. If the Wilwood you now have is non returnable, you could remove the switch and plug all the holes except the RI and RO (Rear In and Rear Out). |
11-12-2019, 09:07 PM | #16 |
Thank's for the help guys, I posted that picture of that other proporting valve because that was the switch i was looking for to possibly be able to make the warning brake light on the guage light up, but i think I'll just plug that off and not worry about hooking that up.
