11-09-2019, 03:06 PM | #1 |
steering stabilizer help
Good Morning.
I purchased a steering stabilizer to put on my build, its a 1972 K10. I hope i can explain this correct. On the drag link the hole (red circle) for the stabilizer to mount to is 26" toward the center of the draglink looking directly at the truck going from the passenger side to the driver side. (29" if you measure from the driver side towards the hole going to the passenger side). The bracket on the front axle (Blue circle) is slightly to the right of the hole in the draglink. The draglink adjustment is far to the right on the driver side (green circle) How am i supposed to mount this? Is this the wrong drag link? even if i was to flip the drag link around so the adjustment was on the passenger side ( i dont know if that would even be correct) the stabilizer shock would still not be able to be mounted due to where the placement of the hole (red circle) is. What would you guys do? I purchased this truck half apart so i don't know if this was even the correct drag link. |
11-09-2019, 03:54 PM | #2 |
Carpe manana
Re: steering stabilizer help
The drag link/tie rod and the axle are not from a 72 model year 4wd GM vehicle.
Here’s an example that’s correct for 72: http://www.67-72chevytrucks.com/vboa...9&postcount=57
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 11-09-2019 at 04:07 PM. |
11-10-2019, 11:00 AM | #3 | |
Is a steering stabilizer really needed? Can i just purchase a different draglink / tie rod setup to add the stabilizer if needed? Thank you very much for your input and time. Lorenzo |
11-10-2019, 01:35 PM | #4 |
Post Whore
I'm sorry I can't answer your questions, but I do suggest that you repost or have a moderator move this thread to the 4x4 section. You will find a larger audience that has had experience with what you are up against.
Good luck.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
