Old 11-11-2019, 06:39 AM   #1
papsoldblue72
papsoldblue72's Avatar
Flip kit
I have a 72 C10 with leaf springs …. Will a 73-87 flip kit work with my truck or do I need something else???
It's been a long time coming... It's time to get it done..
papsoldblue72 is offline   Reply With Quote
Old 11-11-2019, 08:33 AM   #2
Mike C
Mike C's Avatar
Re: Flip kit
You need something else. The 73-87 C10 uses a 2 1/2” wide leaf spring and your ‘72 is 2 1/4”.
DJM makes a flip kit for the 69-72 trucks and I got mine from Summit racing. It was hard to find on the website because of a poor description. You may want to use the phone.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-11-2019, 10:27 AM   #3
Speedracer39
Speedracer39's Avatar
Re: Flip kit
I also have the DJM flip kit on my 72 c10 — works great, I purchased mine from the DJM website also put on new leaf springs but removed the overload spring at the same time.
Speedracer39 is offline   Reply With Quote
Old 11-11-2019, 10:12 PM   #4
Mike C
Mike C's Avatar
Re: Flip kit
I removed my overload as well, but only because it hit the CalTrac bars. Or they hit it.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 11-12-2019, 04:15 PM   #5
Speedracer39
Re: Flip kit
I was wondering if the CalTrac bars made the ride any stiffer for a daily driver?
Old 11-12-2019, 07:53 PM   #6
54blackhornet
54blackhornet's Avatar
Re: Flip kit
Can anyone comment on the DJM install ? Is removing bed advised ?
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 11-12-2019, 07:58 PM   #7
Speedracer39
Re: Flip kit
I had mine off only because at the time I did a c- notch and a Boyd tank install—- It is absolutely doable with out the bed removed.
Old 11-13-2019, 08:39 AM   #8
Mike C
Mike C's Avatar
Re: Flip kit
I don’t think so. You can adjust them to vary when they start working. I was actually shocked at how much windup was in the leaf springs even with the 307 motor and 3.07 rear gear. “Throttle response” improved dramatically because now it moves forward when you push the gas rather than winding up the springs and then moving forward. All in anticipation of 427 power in the future...
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 11-13-2019, 08:40 AM   #9
Mike C
Mike C's Avatar
Re: Flip kit
I did mine in the driveway, bed on. You will spend more time on your back, but wasn’t worth removing the bed IMO.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 11-13-2019, 05:11 PM   #10
54blackhornet
Re: Flip kit
Thanks guy’s, I have heavy duty rear spring option. Truck has Low mileage and seldom loaded so was planning on removing the extra spring/springs, will this along with the flip kit get rear end down any significant amount ?
71 C-20
07 Magnum RT AWD
Old 11-13-2019, 06:26 PM   #11
KY_GMC
KY_GMC's Avatar
Re: Flip kit
I had the same spring package on mine and did what you are describing.
I think that there was around a 7" drop. There will not be a lot of room between the axle and the frame. You will have to cut down the bump stop.
Also, move the rear upper shock to the hole next to the existing mount. This will straighten the rear shock to a more vertical position, improving the shock performance. You will need to get an upper shock bolt for the hole.
1972 GMC 1500 Super Custom, 383 Stoker, TH350
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592157
Engine Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592233
KY_GMC is offline   Reply With Quote
Old 11-13-2019, 08:19 PM   #12
Mike C
Mike C's Avatar
Re: Flip kit
My truck also had the 4 leaf HD spring setup. The flip dropped the back of mine 7 1/4". Like KY GMC, I moved my shock to the more vertical position. I re-drilled the hole and used a 69 Camaro multi-leaf mount I had in the parts box.
My front is dropped 2 1/2" with spindles and 2" more with springs for a 4 1/2"-7" drop. I ran 4 front shocks all around.
44 Willys MB
52 M38A1
64 Corvette Coupe
