11-11-2019, 12:58 PM | #1 |
6 cyl 3 on the tree shift rod question
Does anyone know where I can buy new bushings and grommets for the shift control rods ? Maybe a part number that would replace them ?
11-11-2019, 10:40 PM | #2 |
I am a Referee of life.
Re: 6 cyl 3 on the tree shift rod question
Here's thread you need to read. It has some sources for the parts in the comments.
http://67-72chevytrucks.com/vboard/s...d.php?t=215307
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
11-12-2019, 12:16 AM | #3 |
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
11-12-2019, 12:19 AM | #4 |
11-12-2019, 12:51 AM | #5 |
Old member
I found this for you in another thread but should be good to go.
http://67-72chevytrucks.com/vboard/s...d.php?t=505012 https://www.classicparts.com/1960-76...ctinfo/91-063/ https://www.classicparts.com/1947-76...ctinfo/91-062/ https://www.classicparts.com/1960-72.../#.U7wTW41dW2N
11-12-2019, 08:01 PM | #6 |
Lots of good info here. Hope to find this when I need it.
Tags |
shift rods |
