11-11-2019, 02:24 PM | #1 |
Source or part# 69 C20 HO52 5 bolt pinion flange gasket?
Resealing the HO52 in my 69 CST20. Not finding a gasket for the pinion flange anywhere. Thought I would be able to just use RTV, not possible, the mating surfaces will not come together the way the flange is machined without a gasket. I’ll just buy some gasket material and make my own if one is not available. Thought I would give this a shot to see if any of you might know of a source and part number for that gasket.
Steve weim55 Colorado |
11-11-2019, 07:21 PM | #2 |
Re: Source or part# 69 C20 HO52 5 bolt pinion flange gasket?
Nothing wrong with making one. That's what I had to do for my axle flange/brake backing plate gaskets on my Dana 44 rear end.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
11-11-2019, 11:49 PM | #3 |
It will take some extra thick gasket material. The gasket has to fill in the gap between the flange & housing. The original is a thick cork gasket.
George |
