Old 11-11-2019, 06:26 PM   #1
71c10longbed
Cab supports again...
On my 71 I am replacing the front cab support on the passenger side. My floor is still in place. On my drivers side I was able to cut out the rusty part and weld in patches. The passenger side is completely gone. I have removed a portion of it from the rocker back. I can't figure out how to get the rest out that is buy where the cab bushing nut goes through - between the floor and cab frame. I am using an air chisel but it only seems to be making noise. Any ideas?
71c10longbed is offline   Reply With Quote
Old 11-11-2019, 07:58 PM   #2
MDPotter
MDPotter's Avatar
Re: Cab supports again...
You probably already know this, but it is very difficult to perform these repairs with the cab on the truck. If it's a solid running truck and you don't want to pull the cab, you might just have to weld onto what's there or sleeve over it. Or one of those oscillating saws might be able to reach in there and free things.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 11-11-2019, 09:04 PM   #3
twoskies
twoskies's Avatar
Hey , good job so far, did mine last year, i know i had to air chisel mine out
(used a cheap harbor freight and a squirt can of oil, keeps it cutting easier), including the metal sleeve, my cab support bushings came with new metal sleeves, kinda a pain to install but i made it work, on the driver side, i spliced also, the passenger side was too far gone like yours, i did mine without removing the cab, does make more work , but it will work,also make sure you coat anything you,re going to and let it dry before more welding, lol, little harder after its done, sorry, looked for pictures but could'nt find any
A Little Better Every Day
Cancer Survivor, most dont know what they have until its gone, appreciate everything
twoskies is offline   Reply With Quote
