Old 11-12-2019, 04:09 PM   #1
San Diego Ron
San Diego Ron's Avatar
Holley Choke on '71 C-10
Don't let this happen to you...Coming off freeway off ramp at highway speed truck had throttle stuck open and could have caused terrible accident by plowing into stopped traffic ahead of me. Was able to get stopped and idled down manually, made it home taking back roads at idle speed. First thought linkage or throttle cable then finally saw that piece was broken off choke idle cam and was getting stuck in linkage. New part should be in today...a $10. plastic piece that should have been made of metal.
San Diego Ron is offline   Reply With Quote
Old 11-12-2019, 04:31 PM   #2
68Stepbed
68Stepbed's Avatar
Re: Holley Choke on '71 C-10
Wow!! Been around hot rods and classics my whole life and never seen an idle cam break! It must've just dry rotted.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-12-2019, 06:36 PM   #3
geezer#99
geezer#99's Avatar
Plastic doesn’t dry rot.
Likely carb got bumped or dropped against something and cracked.
Holley wasn’t the only carb like that. Quadrajets had a high idle cam that was plastic.
Old 11-12-2019, 07:28 PM   #4
54blackhornet
54blackhornet's Avatar
Glad you are ok man ! Quickly thinking saved you....
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
