Old 11-13-2019, 03:22 AM   #1
Dodge68charger
Fuse Between Alt n Battery
Cant Find a Definite Answer. Some Say Yes, Others Say Dont Bother
If So What Size Fuse For a 140 Amp Alternator?
Its a One Wire. Not Sure How To Wire It. Wire From Alternator To Battery or Can It Be Wired To The Starter Solenoid?
Can The Fuse Box Be Powered From The Starter Solenoid?
Is The Painless 30700 Kit An Idea...
Just Dont Want a Fire.. Thanks Guys
Dodge68charger is offline   Reply With Quote
Old 11-13-2019, 09:09 AM   #2
rpmerf
rpmerf's Avatar
Re: Fuse Between Alt n Battery
I have a 30 amp fuse right after the battery. The only time it ever popped was when my voltage regulator died. I do have a mostly factory truck, so even with lights, radio, and HVAC running, I should be around 30 amps. With the factory setup, the power will pull from the generator instead of the battery, since the generator is located between the battery and the fuse block. The only thing going to the battery should be for charging the battery.
I have considered putting a big fuse right after the alternator. Some food for thought. Say your alternator wire hits the header and burns through. The fuse on the battery should pop right away. Once you shut the engine down, the alternator is no longer supplying power.
This does also depend on exactly how you have it wired. If you have the alt on the passenger's side, wired to the starter, then I would be much more inclined to have a fuse. I believe OEMs use a fuseable link between the alternator and battery. I'm pretty sure that's how it is on my 97 Suburban with a 140 amp alternator.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 11-13-2019, 03:11 PM   #3
HO455
Post Whore
HO455's Avatar
What you should install is a fusable link not a fuse. The OE's don't use fuses. They will protect you from short circuits but won't arbitrarily fail (as will fuses do) and cause damage to the alternator. Here is a link to my repair thread look to post 469 for more information on fusable links.
http://67-72chevytrucks.com/vboard/s...698377&page=19
This link will help you on how to correctly wire your new alternator. Plus tons of other good information.
http://www.madelectrical.com/electri...evymain1.shtml
Hope this helps.
RIP Bob Parks.
Old 11-13-2019, 03:28 PM   #4
weq92f
weq92f's Avatar
FWIW, I'm going with a fusible link to protect mine. Alt goes to bus bar via 6ga cable. I'm going to install about 6 inches of 8ga fusible link wire between the alt and the bus bar.
Hth,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
