Old 11-13-2019, 07:44 PM   #1
Chev1171
1960 door glass install
Removed my door glass to repair regulator rollers. Need help re-installing door glass into regulator track
Chev1171 is offline   Reply With Quote
Old 11-14-2019, 05:15 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 1960 door glass install
This thread - http://67-72chevytrucks.com/vboard/s...d.php?t=578824
Old 11-18-2019, 12:49 PM   #3
jbgroby
jbgroby's Avatar
Chev,
I made a picture tutorial when I installed my vents and glass. I hope this helps.
Step 9: Attaching the Regulator to the Glass Frame
Ok, so far it’s been a bit long, but this step may find you cussing a little. You now need to fit the upper rollers in the window grove channel. BUT HOW YOU ASK - AS THEY DON’T MATCH UP. You will need to undo the two screws holding the groove to the window frame, have your helper hold onto the window in case it wants to slip, but I found that the tension and the felt held mine in place. You then slide the grooved channel over both rollers, you work the channel back and forth till you can get over the rollers and reset the screws. You will need to roll the regulator up sill it in the position shown. This seems hard but it is not. Once you put the screws back, you need to cycle the window a few times to see if it binds. Sometime a bit of graphite may be needed in the groves.
http://67-72chevytrucks.com/vboard/s...d.php?t=718048
jbgroby is offline   Reply With Quote
