Old 11-13-2019, 08:16 PM   #1
novice
CPP rear disc question
Is this the normal surface area coverage for rear brakes? Seems awfully small surface coverage.
novice is offline   Reply With Quote
Old 11-13-2019, 08:49 PM   #2
novice
Re: CPP rear disc question
Any help appreciated.
Old 11-13-2019, 09:41 PM   #3
geezer#99
geezer#99's Avatar
Looks right.
Rear brakes only do 30% of the braking so no huge Calipers are needed.
geezer#99 is online now   Reply With Quote
Old 11-13-2019, 10:04 PM   #4
novice
Originally Posted by geezer#99 View Post
Looks right.
Thank you. Just looks odd to me.
Old 11-13-2019, 10:11 PM   #5
BigBird05
You should have full pad contact.
BigBird05 is offline   Reply With Quote
Old 11-13-2019, 10:42 PM   #6
clay68c10
clay68c10's Avatar
Definitely not getting full pad contact. How many miles have you driven it? The pads don’t always make even contact right out of the box, but should wear in within a couple of miles.
It looks like the bracket/caliper is a bit too far out (or maybe crooked) but I’m not familiar that particular setup.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 11-13-2019, 10:52 PM   #7
KMC3420
KMC3420's Avatar
I agree, looks like the pad is not making full contact. Do you have any miles on this setup?
Is this the kit?
CPP kit
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 11-14-2019, 08:11 AM   #8
novice
Is this the kit?
CPP kit
I don't even have a full mile on it yet.
Yes it is a CPP setup.
Old 11-14-2019, 11:40 AM   #9
KMC3420
KMC3420's Avatar
Is the brake pad extending past the rotor any? The picture makes it look that way, but that might not be the case.
Keagan
Old 11-14-2019, 11:52 AM   #10
novice
I'll take a look and better pictures this afternoon.
Old 11-15-2019, 10:32 AM   #11
novice
Apparently I can't upload pictures now.
However, only the top section of the brakes are touching and the pads do not extend past the rotor. So like previously suggested, the brakes may just have to be "worn in" more.
Old 11-15-2019, 11:21 AM   #12
BigBird05
What does the contact pattern look like on the back side? Brakes should fit when installed, not have to "wear in" to get full contact. You should contact CPP.
Old 11-15-2019, 11:24 AM   #13
KMC3420
KMC3420's Avatar
If you have 100% brake pad contact on your rotor then it is setup as it should be. Putting some miles on it will show you the wear pattern and you will be able to better determine at that time. My wife's Subaru has small rotors and pads such as yours on the rear, but the front is much beefier, as I suspect your truck is as well. What do you mean by only the top section of the brakes are touching?
Keagan
Old 11-15-2019, 11:39 AM   #14
KMC3420
KMC3420's Avatar
This is accurate, the Brake pads should sit parallel to the rotor. Are you stating that the brake pad is only touching the rotor in the area in red below, hence the original pattern we are seeing. It appears based on what you are saying the brake pad is only engaging the rotor 1/4 of the way, and it should have a full wear pattern, the width of the brake pad, on your rotor. Did your brake conversion kit come with any shims for behind the mounting bracket?
Keagan
Old 11-15-2019, 11:55 AM   #15
novice
Maybe they'll work
Old 11-15-2019, 11:57 AM   #16
novice
Couple more
Old 11-15-2019, 11:59 AM   #17
novice
Last two
Old 11-15-2019, 07:47 PM   #18
BigBird05
The photo in frame #15 looks like the inside brake pad is very small. It should be the same size as the out side pad. You might have the wrong set of pads.
Old 11-15-2019, 09:19 PM   #19
novice
Perhaps. I've verify but as you can see in the next to last photo, the coverage area of the inside pad is nearly the entire rotor surface.
