JEDDY II Captain Fab and to all my C10 friends
Hey everyone,
It’s been years since I’ve posted anything here. God I hope everyone on the other side of the pond are doing well🙏. I regret to inform you that in the summer of 2016, Jeddy I (1963 c10 LB step-side) was stolen from the parking lot of the BellaSky Hotel in Copenhagen, Demark. I was on my way to Stockholm, Sweden on a summer European tour. I’ll try to post pics here🙏. Since then, I have purchased Jeddy II, a 1963 SB step-side from Worldwide Vintage Autos in Denver, Colorado. The past few years I’ve been working on an off frame restoration on this truck. You can also follow the build on Instagram under: c10_trucks_jeremy_franklin Here’s a short breakdown of new parts For JEDDY II: 540 Pro/Street Big Block Chevy: Dart 4 Bolt Main Block Painted Orange, 4340 Forged Steel Crank, H-Beam Steel Rods, Forged 10.5 To 1 Compression, Complete Assembly Blue Printed And Internal Balanced, Comp Cams 652/652- 262/262 Roller Cam And Lifters, Comp Cams Double Roller Timing Chain And Gears, Polished Aluminum Timing Cover, Moroso 7 Qt. Oil Pan, Sfi Balancer, Polished Rectangular Port Aluminum Heads With Manley Stainless Steel Valves, Comp Cams Valve Springs, 10° Chrome Moly Retainers And Locks, Jomar Stud Girdles, Polished Aluminum Valve Covers, Polished Aluminum Intake, 950 Holley Carb, MSD Ignition, Set up, Run, Synchronized and Dynoed. Transmission: Black TH400 Full Manual Valvebody and 3500 stall convertor Suspension: - DROP SPINDLE DISC BRK WHEEL KIT 5 LUG 2-1/2 DROP - SILVER TUBULAR CONTROL ARMS - FR COIL SPRINGS & SHOCKS 1 DROP - RR COIL SPRINGS & SHOCKS 4 DROP - RR SHOCK RELOCATION KIT - ADJUSTABLE TRAC BAR - REAR COIL SPRING RETAINERS - STEERING BOX - COMPLETE STEERING LINKAGE - HAND-MADE BB MOTOR MOUNTS - POLY GM TRANS PAD ( WAITING ON NEW TRANNY CROSSMEMBER FROM POL) - TRAILING ARM 1-1/4" - FRONT BAR & 1-1/8" REAR BAR - POLY RR TRAILING ARM BUSH - BUTTON BUMP STOP - FORD 9 INCH THIRD MEMBER WITH 3.55 GEARS WITH TRUE-TRAC SPORTSMAN GEAR CASE - RACE PINION SUPPORT AND 1330-SHORT YOKE - CURRIE-BUILT CRATE REAREND (1/2" STUD) 5X5 LUG - FORD 9 REAR DISC KIT 3/8 MOUNT BOLTS; 5 X 5 1/2 - REAR AXLE BRAKE LINE KIT - BASIC STREET BEAST HYDRAULIC BRAKE KIT - 4' RUBBER HYDRAULIC BRAKE ASSIST HOSE KIT - ALUMINUM POWER MSTR CYL - PWR DISC FR LINE KIT - FINE LINES 2WD LINE W/ UNION SHORT BED - REAR FLEX BRAKE LINE KIT AWAITING PARTS: - NEW TRANSMISSION CROSSMEMBER - NEW TRAILING ARMS CROSSMEMBER Frame: - STRIPPED - FIRE GALVANIZED Well, all that has taken two years (Jeddy I took 6 years to build). Wishing everyone all the best, and God bless. Jeremy Franklin Duesseldorf, Germany |
Never Ending Projects
Re: JEDDY II Captain Fab and to all my C10 friends
Bummer about the first truck being stolen but glad you were able to move forward and start a new build. Keep up the good work.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Hi Chevy Mike,
Thank you for the encouraging words. One thing I’ve learned in life...NEVER GIVE UP!!!! I’ll keep y’all up-to-date on the Jeddy II Project. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Welcome back Jeremy
![]() Yes that is really too bad that your first truck was stolen. Jeddy II sounds like an awesome truck, especially the engine. I'm looking forward to seeing your progress here.
Stunning Project! That parts list is just awesome and that engine should be alot of fun!
Did you build it yourself? |
