Old 12-05-2003, 02:36 AM   #1
skokie
skokie's Avatar
Intake Manifold
I am using the rtv instead of the rubber gaskets. Should there be a line of rtv on the bottom of the front and back?
skokie is offline   Reply With Quote
Old 12-05-2003, 02:43 AM   #2
DanoDMano
Pronounced "Pew-al-up"
DanoDMano's Avatar
I would say definitely, but the rubber seals work great!! If you cant get the rubber ones then the RTV should work.
Classic GM Trucks of Washington Club Member
1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's,
Power Locks,
Truck Photos
DanoDMano is offline   Reply With Quote
Old 12-05-2003, 02:52 AM   #3
lukecp
Formerly yellow72custom
lukecp's Avatar
Yup, just lay a 1/4" wide of RTV at the front and back of the block. I use Red RTV myself, but black also works pretty good
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 12-05-2003, 02:55 AM   #4
jorgensensc
jorgensensc's Avatar
I like the copper rtv myself, everyone has a favorite it seems!!!
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 12-05-2003, 03:29 AM   #5
redbowtie
No offence but....throw the rubber ones in the trash.
Use sealer.
redbowtie is offline   Reply With Quote
Old 12-05-2003, 09:48 AM   #6
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
Use sealer.
Agreed!
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 12-05-2003, 12:41 PM   #7
rickspickuppart
Use sealer.
I Agree also
Shawn
rickspickuppart is offline   Reply With Quote
Old 12-05-2003, 06:58 PM   #8
skokie
skokie's Avatar
I had the wrong gaskets to begin with. I had the blue ones the 1256s are black. OOOPPPSSSS. Well at least I didnt fire it up and I got a trial run of putting the manifold on. Live and Learn.
Old 12-05-2003, 07:02 PM   #9
metalman
Originally posted by rickspickuppart
I Agree also
Shawn
I agree as well.
Once the rubber ones pop out on you, and you have to do it all over, you never go back to using them.
I have never had a problem using sealer.
I better shut up . Now that i said that i will get leaks everwhere.
metalman is offline   Reply With Quote
Old 12-05-2003, 07:26 PM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Skokie, when I told you, via PM, to use silicone instead of the rubber gaskets, I knew what I was talking about.
I sat through a GM training class when I worked at the dealer that was 8 hours of tips on stopping oil leaks.
Seems like everyone else here agrees with me too huh?
Piss on whoever told you to not use Blue Fel-Pro gaskets. That's all I've used for 15 years now.
When I offered you advice via PM, I only tell you what I KNOW to work from years of experience. You won't ever see me say "I heard" this or "someone told me" that.
When I said GM policy is to not use the rubber gaskets, to use silicone instead, I wasn't just pulling it out of my rear.
Old 12-05-2003, 07:32 PM   #11
cableguy0
i agreed we build engines everyday and we throw away a lot of the little rubber ends. whoever told you not to use felpros do yourself a favor and dont listen to anything else they tell you because they are a moron. every race engine we put together gets fel pros as well as the street engines and we dont have leak problems
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-05-2003, 08:06 PM   #12
DanoDMano
DanoDMano's Avatar
My Felpro set included the blue gaskets and the rubber ones which I used. They dont leak, and they fit nice????
Are you talking about the rubber ones that come with the Felpro set, or something else??
Power Locks,
Truck Photos
Old 12-05-2003, 08:17 PM   #13
Tx Firefighter
Yes, the Fel-Pro set comes with two sets of rubber end gaskets, the ones with the tits and the ones without.
GM did a study that determined the rubber would pooch out of place over time causing an oil leak. So, they decided to do away with the rubber end pieces and use big bead of silicone only. Warranty oil leak repairs drastically decreased after this change of policy.
Since then, saavy guys have taken the ball and run with it, throwing them away and using silicone on the Fel-Pro sets too.
If you buy a Fel-Pro intake gasket set for a later model SBC, like an early to mid 90s model, it will come with a small tube of black silicone in the box with the two side gaskets, and no end pieces. They even include a little instruction sheet in there to inform the old school guys how to apply the silicone properly.
There is nothing wrong with using the rubber end pieces, but down the road a ways, it is more likely to develop an oil leak from there.
Old 12-05-2003, 08:23 PM   #14
DanoDMano
DanoDMano's Avatar
Thanks for the information. I will have to keep an eye on it for leakage. I have learned in the past that RTV is my friend!
Power Locks,
Truck Photos
