Old 11-17-2019, 12:58 PM   #1
Enduro55
Installing inner fender well??
I am finally putting my truck back together.
I lowered my truck and my new relocated upper shock mounts now seem to be rubbing on the bottom of the inner fender well. Is this normal ? Do I need to cut the inner fender to accommodate the new mounts or is there another trick I can do to not cut the inner fender? Thanks for the help...
Enduro55 is offline   Reply With Quote
Old 11-17-2019, 01:21 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Installing inner fender well??
Probably. Do you have a picture of them installed?
Old 11-17-2019, 01:48 PM   #3
Enduro55
Thanks for the response... attached is a picture. My husband I are thinking we will grind the top of the mount and add washers behind lower fender mount so I will have clearance around an 1/8” ... thanks, Angie
Old 11-17-2019, 02:27 PM   #4
The Rocknrod
Moderator
Or find a shorter shock.
Not sure I'd weaken the shock mount though, but that's just me.
Old 11-17-2019, 04:09 PM   #5
vin63
It's Better With Nitro
vin63's Avatar
Mine is close, but I think my upper mount is located a little closer to the cab.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 11-18-2019, 05:18 PM   #6
forestb
forestb's Avatar
Can you just bend the lip of the fender a little bit? Or unbolt the bolt in the picture and move that side up a little?
forestb is offline   Reply With Quote
Old 11-18-2019, 11:50 PM   #7
Captainfab
60-66 Nut
The correct thing to do would be to trim the bottom edge of the inner fender.
Old 11-19-2019, 04:15 PM   #8
63burban
Chevy addict
It doesn't look like you have the rubber bushings in between the inner and the bracket, that would make the difference
63burban is offline   Reply With Quote
