11-17-2019, 08:00 PM | #1 |
Eaton Trutrac - Pinion Depth
I知 working on installing an Eaton Truetrac limited slip. I am using the original 3.73 ring gear and pinion. When setting pinion depth, should it be real close using the existing shim that was on the OE install? Wondering how much I値l have to play with that. I知 reading that even using a setup bearing, even of the same brand, it could be off. Looking to see other痴 experience using existing gears.
