![]() Join Date: Nov 2018
L6/SBC/BBC/Trans/Driveshaft/Crossmember Swap Matrix
I see lots of piecemeal info from where someone says something like "I've got an L6 with a 3-speed Saginaw, and I want 454 with a 700R4, what do I need?" and such.
Has ansyone ever considered consolidating this into a big "I am here, I want to go there" matrix to figure out what you need for the swap, what can remain the same, etc? In my case, L6 with a 3-speed Saginaw, and I want to go to a L6 with a TH350. I can (and will) search the the forums to find out if I need a different crossmember (and which one), and if I've got to change the driveshaft length or not. But it seems like it'd be pretty cool to point everyone at an Excel or Google spreadsheet, and say "This has everything you need to know".
1970 C10 LWB Stepside 1971 Dodge Dart 1993 Buick Roadmaster Estate Wagon |
#2 | |
Re: L6/SBC/BBC/Trans/Driveshaft/Crossmember Swap Matrix
Remember that TH350's came in long and short output shaft. That will obviously make a difference. IDK which is the same length as the 3 speed. I know the TH350 short shaft that I put in my 55 sedan was a little longer than the 3 speed I took out. I had to get the DS shortened about an inch IIRC.
#4 | |
I see posts where people say the Saginaw is the same length as the 6" version, but I haven't found anything that actually shows a specified length.
